08 Edge... No PS brake light or taillight - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 06-23-2013, 03:27 PM
MotorPool's Avatar
MotorPool MotorPool is offline
MotorPool is starting off with a positive reputation.
Hello all... I have a 2008 Ford Edge with 90xxx miles... vehicle came in with no passenger side turn signal... I replaced the bulb to no avail... I checked the wiring with a test light and now I have no brake light or turn signal. I have heard about possible melting/relay issues with these vehicles. Should I replace the fuse and the tail/stop light relay and go from there? The light socket appears to be slightly overheated but it does work. TIA
Old 06-26-2013, 11:25 PM
MotorPool's Avatar
Just an update on the problem. I switched the sockets and bulb from the passenger side to the drivers side and they work correctly so I know the socket isn't bad. We checked all the fuses and found a bad 15 amp fuse. We now have running lights but still no brake light or right turn signal. I checked the fuses/relays under the dash and the relays/fuses under the hood. Did I miss anything?
Old 06-30-2013, 09:53 PM
texan2004's Avatar
texan2004 texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
Did you verify the brake/turn signal worked when you switched them with the driver side? The only work I have done to this vehicle in the 65K miles we have owned it (since new) is to replace those bulbs. I have done the passenger side once and the driver side twice.
turn and brake light? mr.lothar Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 2 08-08-2016 06:47 PM
Lights acting weird 1988 E-150 snavemit 1968-2013 Full Size Vans 2 02-04-2016 09:16 PM
Trailer connector-no brakes or turn signals RUSTANG67 2009 - 2014 F150 4 07-18-2015 08:25 PM
Brake lights staying on. Need help 79schaefer 1999 to 2016 Super Duty 7 06-05-2015 10:25 PM
Turn signal malfunction issue caused by brake light circuit jakegypsum 1999 to 2016 Super Duty 3 01-09-2014 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
