major spark plug issue - Ford Truck Enthusiasts Forums
Old 06-22-2013, 07:50 PM
huntdiamondjim huntdiamondjim is offline
huntdiamondjim is starting off with a positive reputation.
Hi everyone.
I was working on my nephews 2005 F150 changing his spark plugs for the first time. Truck has 130000 miles on it. Bought the lisle tool, before beginning the job. Began on the drivers side, first two broke off, tool worked great. Began working on the third one and it broke off, and instead of the shield coming out, it stripped metal from cone. Now I cannot get a grip of shield to pull on. I am sure somebody has had this happen to them...Any suggestions?
Thanks Jim
Old 06-25-2013, 09:08 AM
jp4lsu jp4lsu is offline
jp4lsu is starting off with a positive reputation.
How many attempts did you try to get the extractor threaded in?
Is it possible to press the porcelain down further into the shield to hopefully get a little more bite on the metal shield?
You could maybe try turning the motor over. Maybe you would get lucky enough that the compression in the cylinder would dislodge the stuck sheild and push it out.
Old 06-25-2013, 10:07 AM
tooldad tooldad is offline
tooldad is starting off with a positive reputation.
I second trying to press the ceramic down further. Probably will cause particles to drop into the cylinder, so consider trying to vacuum it out (different opinions out there on necessity). Also, double check the Lisle thread. On my 7th broken plug, the thread stripped and failed to pull the shield out. Found a replacement thread tool on ebay.
Another spark plug story milliesdad 2004 - 2008 F150 4 04-01-2016 07:31 PM
'64 F350 292 Heat Shields ihcc104 1961 - 1966 F-100 & Larger F-Series Trucks 8 12-18-2014 12:03 AM
Broken Spark Plugs Dwayne42 2004 - 2008 F150 68 09-13-2014 11:35 AM
V8 5.4 Triton Spark Plug Broke off RollinNtheHay33 1999 to 2016 Super Duty 2 12-05-2011 12:02 PM
Lisle tool didn't work, need ideas mustangski 2004 - 2008 F150 22 06-23-2010 08:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
