Turbo individual parts ? - Ford Truck Enthusiasts Forums
Old 06-22-2013, 04:35 PM
nomad221's Avatar
nomad221 nomad221 is offline
nomad221 is starting off with a positive reputation.
Bent the oil seal ring while inserting the shaft into the center cartridge
Bent the old one too
Does anyone know of an outfit that sells the small parts ?
Old 06-22-2013, 09:26 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Have you checked with riffraff or diesel orings
Old 06-23-2013, 06:39 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Maybe Ron's turbo's? He does MANY rebuilds.
Old 06-24-2013, 08:41 PM
nomad221's Avatar
Thanks guys. After buying a newly rebuilt 66mm TP38 from James (Barders), he educated me on how to install the oil seal ring, (and he has screwed up a few too LOL),
When inserting the shaft into the bearing cartridge, roll the seal in, do not tap it in.
I chaffed the housing and shaft. Couldn't trust the turbo anymore and considering the remote areas I drive too and work at I just went ahead and got a new one.
Should be fun with the new sticks soon.
2011 Super Duty Wheel Bearings bcham5 1999 to 2016 Super Duty 3 08-08-2013 01:13 AM
ICM are not good!! autochefc 1978 - 1996 Big Bronco 2 07-10-2013 07:18 PM
wont turn over when its hot outside jennagirl 2004 - 2008 F150 9 06-19-2013 09:48 AM
oil pan 1969furd 2004 - 2008 F150 4 05-28-2012 11:14 AM
postive battery cable joe f350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 06-10-2010 01:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
