what is "proper" engine break-in procedure?
on
nearing the end of my 351C rebuild and am confused on what the proper procedure is for engine break in.
ive heard to not let it below 1500rpm for the first 30minutes,
not to go above 1500rpm for the break in,
not above 2000rpm for 1000 miles,
start it up, rev it up, hope it don't blow up,
got new iron rings on a fresh hone job,
new cam, lifters, pushrods, rockers, valves, valve guides, and valve springs,
new cam bearings,
new timing set,
new oil pump, (rebuild kit)
what is the best/ most widely accepted break in procedure?
new cam bearings,
new timing set,
on
yea that's what I had always thought, run it like its running. and that keeps the oil pressure up too.
I bought some lucas break-in additive for it too.
another question just popped into my head, its gonna have to run low for the first few minutes to get the timing set... is that gonna cause a problem?
Correct break-in is to get the engine up to 2000-3000 rpm and then vary it within that range for 20 minutes. Don't set it on fast idle and leave it or keep your foot on the accelerator in one place. Being splash lubricated you want all to reach all areas of the new camshaft.
Then run the engine for 50 miles, dump the oil and change the filter. Since flat tappet use the right oil especially for break-in. Could be Brad Penn, or Gibbs, or as simple as Valvoline VR-1 10W-30 Racing oil. After that you might use the same oil for regular use. I use that in my Cougar's engine while four others use Delo 15W-40 which has very high levels of zddp that reminds one of days past.
very helpful website-backs up a lot of historical and not always proveable point about this type of break in.
big one is very careful of flat tappet cams and use ZDDP additive and if really worried, a high ZDDP oil for the life of the engine-after that, try this site
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
In a performance motor you want something with zinc and phosphorus for lubrication ALL THE TIME... flat tappet or roller.
Brad Penn oil is good.
RIKIL-X2 on the good oil-
I do believe that the use if an extra break-in additive, especially for the first stage of break in where everything wears in, is good insurance especially if it is cheap (relative).
also DO NOT use synthetic for break in. On the website I posted. Heard it before, but anecdotal.
Since you're asking this in the Performance forum, the answer is NO. I discourage the use of additives because people consider them temporary.
Geez Mark-say what you really feel LOL. I always liked VR1, but couldn't say why-interesting personal experience about the Bpenn oil as it is meant to be pretty special. After my engine build break in and an extra few thous k's I swapped to castrol edge titanium 20w-50. Only minimal running but wouldn't think there will be a problem.
simons22
15
08-22-2015 08:19 PM
Slog58
06-02-2012 03:19 PM
banjopicker66
06-21-2005 01:23 PM
