2000 Navigator Wet Passenger Floorboards
Hello,
I've used the search function, and all I get is information on 2003-2007 Expy/Gators regarding a/c condensate soaking the passenger floor board. Is this a common issue for Gen1 Expy/Gator as well?
Don't really notice it much driving around town, but took it on a short road trip yesterday and the passenger floorboard was soaked. No color, and no odor, so I don't believe a heater core is the problem. Where, exactly, on this truck would one find the condensate drain line to check it?
Thanks in advance.
Thanks in advance.
Ok, so still haven't found the issue with the wet floorboards (no time to look at it yet), and now that we've had a couple healthy rains the last couple days, I've noticed the problem is worse. Looks like I've got myself two water sources. One related to A/C and one related to rain intrusion. Looks like I'll be removing the cowl and hoping the drains are plugged and it's not a bad windshield seal. Didn't see any water around the door frame, so I don't think it's the door seals that are leaking. Good times. Diagnostic codes are so much nicer to deal with than these look & see type problems.
Kerim1, reps to you.
I had similar issue and it turned out to be a simple seal problem. It was strange how rain went through that hole into passenger side floor.
https://www.ford-trucks.com/forums/1...ide-floor.html
There was a significant increase in floor wetness after the heavy rain though, so I still think I'm looking at two potential issues.
Thanks again all for the help. Hopefully I'll have something useful to report after the weekend.
