Dual fuel tank issue
When the rear tank is selected, engine starts and runs fine. When front tank is selected, it starts very hard, and just sputters. So when i start the truck with the rear tank, I can switch over to front tank, and it runs fine. Its only starting with the front tank that causes problems. Any ideas? Sending unit?
As a matter of fact, I am getting a code: p0174 "System Adaptive Fuel Too Lean Bank 2". One of the ten possible cause that it lists is that "The fuel system may not be supplying enough fuel (e.g. The fuel pump may not be supplying enough fuel)." It also suggest checking for multiple air leaks, MAF sensor, etc. Since I know there is an issue with the front tank fuel pump, and that's one of the possible causes, maybe I'll start there. Oh, and that tank has a very small leak, so maybe I change out the entire tank while I'm at it.
1996 F350 Dually CC
12-13-2013 01:52 PM
Ryan.J.M.
11-01-2012 06:31 AM
Penrider
05-10-2010 03:02 PM
Youngbearman
08-23-2008 01:15 PM
