2013 f250 sits uneven by 1.2"! - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 06-21-2013, 07:06 AM
Doncon1216 Doncon1216 is offline
Doncon1216 is starting off with a positive reputation.
Hello all, I have a new 2013 f 250 gaser the truck I noticed sits crooked it is lower on drivers side by almost 2 inches and not from the fuel tank. Any ideas as this is bothering me it looks cheap for a 50K truck!
Thanks!
Old 06-21-2013, 01:52 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Take it back to the dealer, they have specifications they're supposed to adhere to, this doesn't sound like it'd be within that spec.
Old 06-25-2013, 03:27 PM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
My truck is 1/2" higher on the passenger side than the drivers side front and rear. Had an 08 F350 that the Pas. side was 1" higher than the DS. and the rear was the same on both sides. See what the dealer will do, they did nothing for me on the 08 and my 13 was close enough for me, I measured before I signed.
Old 06-25-2013, 05:00 PM
What is it from? Just poor build or is it comin in a ford?
Old 06-26-2013, 08:10 AM
I think its just that not all springs have the exact same tention plus the body and frame could be slightly off. I would bet you could check any brand of cars and trucks and find some differences.
The only people that really notice are those that go through the trouble to set up there hitch's correctly and actually measure the fenders to see if its set up right.
I did not have any handling issues or tire wear when mine were off.
I have read in the past that some people got the dealer to switch springs from side to side to fix but don't remember the outcome.
Old 06-26-2013, 08:26 AM
So I would think if I went to dealer it would be a waist my time because I'm sure they new at factory its not perfect and would say its in the tolerance? I cant believe they let $50,000 trucks go out the door this way!
Old 06-26-2013, 08:34 AM
I would still try, at least get it on record.
Old 06-26-2013, 11:34 AM
Even if it's a waste of time, at least you have documented the complaint.
Old 06-26-2013, 01:07 PM
Just what I thought they will not do a thing. This is my last ford
Old 06-26-2013, 01:15 PM
You give up too easy????????????
Old 06-26-2013, 01:24 PM
Mabe, but I'll tell you this look at your trucks closely the fit and finish on these 50 k trucks are a joke! That's what you get when union spoiled workers make a us product you get junk!
Old 06-26-2013, 02:30 PM
Troll by.
Old 06-26-2013, 02:47 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Quote:
You are new to FTE so for now I will give you a pass for now but I would like to see photos of your truck so we can see what you think the problem is, myself I don't believe what you are saying so I would like to see evidence. 2 photos with a tape measure showing the difference in the two sides would be nice.
Denny
Old 06-26-2013, 06:26 PM
Did you buy the truck without looking at it? Saying the general fit and finish is a joke is a pretty generalized statement. What other complaints do you have about it?
What'd the dealer say, it was within spec? What's the spec? If it's not, call Ford customer service. You gotta put a little effort into it. I've run into similar "push back" by service advisors, but yours seems self explanatory. If it's within spec, so be it, if it's not, it should be fixed...
Old 06-27-2013, 07:42 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is online now
ATP Pilot is gaining momentum as a positive member of FTE.
my fit and finish is great. go by something else and report back...bye bye
2013 6.2 strange misfire problem johnno5 6.2L V8 4 12-27-2016 06:03 PM
2013 f250 remote start ryanrk12 6.7L Power Stroke Diesel 0 02-13-2016 01:14 PM
Larger tire for my 2013 F250 dbllng65 1999 to 2016 Super Duty 0 05-29-2015 06:20 PM
Suspension Lift F250 2WD 2013 Daldhern 1999 to 2016 Super Duty 0 01-17-2015 12:57 PM
2013 Lariat Rough Ride mmikemitchell 1999 to 2016 Super Duty 2 03-24-2013 11:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
