new 6.2 vs old 3v v10 - Page 2 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 07-03-2013, 02:33 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
I guess I'm glad I never got a 3v V10. Coming from a 2v V10, the 6.2 is a nice improvement.
Old 07-03-2013, 05:04 PM
jbrianas jbrianas is offline
jbrianas is starting off with a positive reputation.
if a read mark k thread correctly, the tq5spd and tq6spd gear ratios 1-5 are the same in both units, #6 is additional overdrive gear
driving around the trucks unloaded, the 6spd is better for me, it pulls lower rpms and nets me better mpg, but all other situations i prefer the 5spd, the factory tuning on the 6spd is horrible for hualing/towing- utter garbage i dont get it (yes using tow/haul mode)
im not really seeing fuel savings with the 12 truck id hoped for and was told to expect, crappy
Old 07-03-2013, 08:23 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
Here's the gear ratios of the old 5-spd vs the new 6-spd.
3.11
2.11
1.55
1.0
.71
3.97
2.31
1.51
1.14
.85
.67
The six speed is geared a bit deeper in first, second and fourth; while the 5-spd's overdrive splits the 6-spd's two overdrive gears.
Old 07-03-2013, 08:36 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
I prefer the 5 speed also. The 6 speed shifting is very lazy. It's a little better when tuned but not as good as the 5 speed.
Old 07-04-2013, 01:05 AM
twigsV10's Avatar
twigsV10 twigsV10 is offline
twigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to behold
Going from a e4od to the 5r110 took me a little getting use to as it is a completely different beast, but the more I drove it and very much more when towing I've been very impressed. I wonder if they are trying to hard with the 6 speed to make the mpg better for the GOV?
Last edited by rvpuller; 07-05-2013 at 08:43 AM. Reason: to remove the 6 speed link
Old 07-04-2013, 11:48 AM
scraprat's Avatar
scraprat scraprat is online now
scraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud of
I think maybe leaving the gears the same and having a 2nd overdrive option to engage. Also, having the 4.30 gears in the v10 and on the long steeper climbs it would drop 1 gear and hold it. It would of been nice to have 4.10 gears in the 6.2 for a more daily ride with occasional towing but gas mileage isn't a concern for myself as it might be for others.
Old 07-05-2013, 01:48 AM
twigsV10's Avatar
Quote:
3.11
2.11
1.55
1.0
.71
3.97
2.31
1.51
1.14
.85
.67
The 6 speed should be better with these gearing numbers but where the EPA thinks it should shift for mpg and where we want it to shift aren't always the same. Tuning as always will get better with time.
Last edited by rvpuller; 07-05-2013 at 08:44 AM. Reason: To remove the 6speed link
looking to buy sd 6.2 davidaz 6.2L V8 23 01-21-2017 08:38 AM
Possibly upgrading to a 6.2 SD from a 6.8 3v v10 FX4Range R 1999 to 2016 Super Duty 2 10-02-2013 09:38 PM
2003 V-10 vs 2012 6.2L gas ungerp 1999 to 2016 Super Duty 14 07-28-2012 08:01 PM
6.2 boss...any good? pkenn7 1999 to 2016 Super Duty 10 05-23-2010 10:18 PM
6.2 is the new V-10 wendell borror Modular V10 (6.8l) 19 11-15-2008 01:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
