vaccum help for heater
I have a 79 cab with A/C and a 460. . I am trying to hook up vacuum lines. I think one goes from firewall by drivers side to canister under drivers fender. Them maybe to heater box?
I have searched and searched but found nothing to help me. All my egr, etc has been removed.
Most people are unaware that there were three different types of A/C for these trucks. Factory and two different types of Ford dealer installed.
No vacuum reservoir (mounted on left fender inner apron), no vacuum controlled heater water valve (spliced into heater hose) unless the truck has factory installed integral A/C or Hi/Lo Comfort Vent System.
Factory installed integral A/C combined with the heater, the A/C controls are located in the same panel as the heater controls.
I have a 77 F150 with factory AC with the vacuum canister mounted to the Battery box that is not currently connected. Does this have that 3 way valve your talking about? Do you have a part number? OP, sorry for the hijack
Applications: 1976/77 F100/350 & Econoline / 1978 F100/350, Bronco & Econoline before serial number AJ0,001.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
Early models had three lines that pass through the firewall, later models had two.
There is a vacuum line that goes from the manifold vacuum tree to the vacuum reservoir. Then, the larger diameter line goes from the firewall to the reservoir. The one or two small diameter lines go to the heater water shut off valve located in one of the heater hoses. Early models had two vacuum lines, later models had a single line.
Here's the illustration from the Ford parts catalog, click on the .pdf link.
Under the dash it should be pretty much foolproof. The lines are color coded and go into molded plugs. The plugs only go on one way.
Not sure if the 79 is the same but the pics are of a '76.
The vacuum line goes from the vacuum reservoir through the firewall. It then T's off and goes to both plugs. On the three line plug it's brown, green, black (black is the vacuum line). On the seven line plug, the vacuum line (black) is located between the yellow and green line.
AZHIBoy
10-15-2016 05:28 PM
Beachums
Modular V8 (4.6L, 5.4L)
10-05-2016 06:47 PM
mktsc
11-23-2010 11:01 AM
