Two Piece inner axle seal
Earlier this week I pulled out my right axle shaft and found the outer portion of the Spicer two piece seal attached to the axle, the part number on the seal is 52148. The axle tube is dry, no signs of the seal leaking. I need to remove that seal from the shaft to install a new outer dust seal. Can that seal be removed with a 3 jaw pulled then get reinstalled, or can I get a new 53148 and install that portion with out removing the carrier. I am not set up where I sit right now to pull both axles.
Dan
Dan
