Anyone ever have issues putting key in ignition? Steering wheel is locked on flat ground. Key will not go in! 2013 f150 ecobost, any thoughts would be great
no one here has a truck that new, and this is a offroad forum, you will have better luck in the 09+ im sure.. But
you mentioned the steering wheel is locked, trying seeing if it has in "pressure" on it if so turn it to take pressure of the wheel and see if that helps.....
