55 Yblock help please - Ford Truck Enthusiasts Forums
Old 06-20-2013, 07:26 PM
tnguynaford's Avatar
tnguynaford tnguynaford is offline
tnguynaford is gaining momentum as a positive member of FTE.
I need help with a few questions about my 55 F500 with 239 Y block engine. I don't know what has been changed electrically as of yet. I have found a mix of 6V and 12V parts so who knows. I know it was factory 6V system.
First question: was it original negative ground or positive ground system?
Second question: what is direction of rotation when facing the flywheel? I assume counter clockwise but would like to know for sure.
It looks like PO attempted a tune up but with point gap completely closed and cap turned 180 degrees from its proper spot so the alignment notch holds it up a bit high, I want to start over making sure wires are on right.
I appreciate the knowledge of the fine folks on here and value your advice.
Old 06-20-2013, 07:31 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
It was originally six volt positive ground.
The engine turns top toward the driver side. Facing the front or rear of the engine, it will turn top toward the driver. CW or CCW, = confusion factor.
Old 06-20-2013, 07:54 PM
Kurt G.'s Avatar
Kurt G. Kurt G. is offline
Kurt G. is starting off with a positive reputation.
Does it run? Remember that these old trucks sometimes have had dizzy pulled and #1 locaation does not always line up like book. ALWAYS rotate and find #1 cyl. then set up firing order. Yes cap does need to set all the way down to run. My Y came to me for free because PO had firing order all messed up and motor would not run. I fixed it in like 10 minutes, after that it was bad fuel.
Old 06-20-2013, 08:00 PM
Thanks Ray. That helps. I hooked it up negative ground 6V to spin her over and it turned the direction you indicated. Starter growled bad though and turned really slow.
Old 06-20-2013, 08:06 PM
No, Kurt, it doesn't run yet. I figured after I was sure of rotation I would locate #1 position of the rotor and then be sure not to wire it backwards lol
Old 06-20-2013, 08:31 PM
Are the cylinder numbers still standard Ford order?
Old 06-20-2013, 09:36 PM
raytasch's Avatar
Quote:
Passenger side starting at the front, 1,2,3,4
Driver side starting at the front, 5,6,7,8
The cylinder number should be cast onto the intake runners of the manifold. The firing order should be cast across the manifold in front of the carb.
Old 06-20-2013, 10:03 PM
OK. I didn't see cyl numbers but firing order is there. Thanks ray that helps a bunch.
Old 06-20-2013, 10:06 PM
I would like to have one of those ford parts and or service discs but I don't know where to get them
Old 06-20-2013, 10:14 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Ford-lisenced copies are available on FleeBay.
Old 06-20-2013, 10:49 PM
Thanks Horvath. I will check there
Old 06-21-2013, 06:10 AM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
The starter will take 12 volts if you don't run it too long. You also can hook the start up negative ground and it will still spin correctly. Since it is running slow, that starter might be going. Or you battery needs to be charged. I was able to get a 6 volt starter at Napa for around $60. I will have to find that info. Just did a quick look online and it looks like they want $110.
Here is the shop manual on Amazon in CD format:
1954 1955 Ford Truck Shop Service Repair Manual CD Engine Drivetrain Wiring OEM : Amazon.com : Automotive 1954 1955 Ford Truck Shop Service Repair Manual CD Engine Drivetrain Wiring OEM : Amazon.com : Automotive
I got the actual book because I like holding the pages.
Here is another cd that is a must.
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
Old 06-21-2013, 06:41 AM
Absolutely +1 on the HiPo CD. Between that and NumberDummy (to provide updated part numbers) I have actually been able to find a few precious NOS gems out there to work on our Albatross.
Old 06-21-2013, 11:48 AM
I will for sure get the CDs thanks for the links. I also prefer books over electronic format. This old stuff is a new adventure for me. You guys are shedding much needed light for me.
Old 06-21-2013, 01:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
6 Volt Grounding Points Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-08-2016 02:36 PM
Fog Light Wiring Question Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-01-2016 07:09 PM
1950 F1 (o) Starter solenoid F1rb 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-24-2015 10:48 PM
6V Positive Grounding Questions 46fordgal 1947 and Older Ford Trucks 10 03-13-2015 05:22 AM
Fuel Tank Replacement Sending unit 55 f100 johnson.jeff.a 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-17-2014 07:56 PM
Tags
1955, f100, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
