55 Yblock help please - Page 2 - Ford Truck Enthusiasts Forums
Old 06-21-2013, 05:03 PM
tnguynaford's Avatar
tnguynaford tnguynaford is offline
tnguynaford is gaining momentum as a positive member of FTE.
Thanks albuq. That is just what I needed for this weekend as I plan to get that straightened out.
Old 06-22-2013, 09:36 PM
It runs!!! It runs!!!! I finally got to hear her run just now!
Old 06-22-2013, 10:22 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Congratulations! Did you do anything special to get it running?
Where is the video?
Old 06-22-2013, 11:05 PM
I call it redneck engineering... lol... I finally figured out that although po had installed a few 12V items it is still for sure 6V pos ground. And the plug wires were on wrong and they put dizzy in 180 degrees out. That is why cap was turned 180 degrees from it proper position and the new points they installed were burned up. So, new points, rewire plug wires, I only had a 12v battery and a 12v coil with built in resistor so I isolated the cranking system and ign system with jumper wires, new fuel line and filter feeding from a gas can she came to life! I will try to post video.
Old 06-23-2013, 12:04 AM
Video of Grace 239 y block running for first time in about 18 years.
I had to click on the words to get it to play. I can fix trucks cars and bulldozers, but barely can work the new cell phones lol
Last edited by tnguynaford; 06-23-2013 at 12:12 AM. Reason: cause i dont know what I'm doing
Old 06-23-2013, 12:08 AM
Oops double posted video.
Old 06-23-2013, 12:23 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Congratulations! That's quite an effort you went thru.
Old 06-23-2013, 12:33 AM
Thanks Ross. It was worth it. Now I know I have a good engine.
Old 06-23-2013, 08:05 AM
Harrier's Avatar
Awesome and congratulations. It is such an exciting feeling. Thanks for posting the video.
Old 06-25-2013, 01:15 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Ross, thanks for that picture of the engine. Nice and handy the next time I need it. Jag
6 Volt Grounding Points Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-08-2016 03:36 PM
Fog Light Wiring Question Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-01-2016 08:09 PM
1950 F1 (o) Starter solenoid F1rb 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-24-2015 11:48 PM
6V Positive Grounding Questions 46fordgal 1947 and Older Ford Trucks 10 03-13-2015 06:22 AM
Fuel Tank Replacement Sending unit 55 f100 johnson.jeff.a 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-17-2014 08:56 PM
Tags
1955, f100, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
