2013 F150 Rear bench headrest removal
I removed mine to put a dog cover on the rear seat and I think it was the same as the front ones. There is a push button on the side of the plastic piece where the rods go down into the seat. I don't have a great memory...and I think you might have one on each side and that they both may need to pushed in at the same time. It seems like I remember needing another set of hands to do it, but that I still got it out by myself.
There is a push button each of the 2 shafts of each of the headrests. Push them in and pull up on the headrest. It will help a bunch to have the bottom portion of the backseat folded up....as the bottom folds up, the top moves downward, giving you more room to pull the headrests up, tip the top of the headrest slightly forward and then out.
