ZF5 in a 99 4x4 - am i crazy? - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 08-17-2014, 10:20 PM
300-6 AUTO TECH's Avatar
300-6 AUTO TECH 300-6 AUTO TECH is offline
300-6 AUTO TECH is starting off with a positive reputation.
Do you happen to know what t-case is behind that ZF5 in the e99? I've never looked close at an earlier SD with a 5 speed to see what T-case they used. I would assume it was a NP271/273, but it would either need a smaller splined input shaft or the ZF5 would have to have a larger splined output shaft as compared to the earlier versions used in OBS pickups.
  #32
Old 08-18-2014, 01:23 AM
Here's some good ZF info from the source.
Scroll all the way to the bottom.
ZF Friedrichshafen AG USA/Canada | Print Catalogs
  #33
Old 08-19-2014, 03:24 AM
From what I can tell SD 4R100 and ZF5 transmissions were kept 31 spline outputs while the ZF6 was a 34 spline. So, the auto t-case should bolt onto the ZF5.
I'm going to do a manual swap, few last questions. Ryan313 1999 - 2003 7.3L Power Stroke Diesel 37 09-21-2016 08:17 AM
another zf6 thread... OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 44 11-22-2013 07:09 AM
E4OD to ZF 5 conversion kellens 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-14-2013 01:11 PM
7.3 SD questions from an OBS guy OldWoodsDiesel 1999 - 2003 7.3L Power Stroke Diesel 14 06-04-2013 10:10 AM
Another zf5 Conversion Thread JustDriveTwo 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-15-2012 11:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
