Modular V10 (6.8l)
Low oil in V10
Old 06-20-2013, 10:08 AM
neilc88's Avatar
neilc88
neilc88 is offline
Low oil in V10
Hi guys,
My V10 is starting to use more oil than I realized. 73,000 miles.
It seems to be almost a quart every 1000 miles.
I did my last oil change and got less than 4 quarts out, but put 6 in originally.
Everything is working fine and I never got a low oil pressure indication.
So my question.
Will there not be any engine damage as long as the oil pump intake is still sending oil to the engine??
This makes me sick : to see so little oil come out during the change and I will keep a close eye on it in the future.
P.S. Always use Motorcraft semi-synthetic 5w-20.
Old 06-20-2013, 10:17 AM
cpickner's Avatar
cpickner
cpickner is offline
Your motor should be fine. 4 quarts out of 6 is ok. It is alittle low, but not too bad. Keep checking the level on a regular basis. You may wanna change your PVC valve. If it is clogged, it will increase oil comsumption. Don't ask me how. Some people on here ALOT smarter than me may cime in here.
Have a great day.
Old 06-20-2013, 05:27 PM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
My 2003 behaves the same way . I put 6 qts. in (and add at least 1 qt during the 3k oil change period ) and take out 4-4.5 qts when changing the oil . Also my dip stick is not accurate , it shows half-full mark with 6 qts oil (which is Ford recommendation by the owner's manual).
Ford manual says "do not add if oil level is within the marks" . But at the absence of an accurate dipstick , it is a challenge (even if you re-mark your dipstick for your own "new full mark " . There is always a question about the accurate 5 qts level.
If you did not change your own oil , you would not have a clue about how much oil is coming out . So, relax , you are not alone.
PS.
I wish I could have the answer for the minimum oil level required for proper lubrication . Let me see what I need for that ;
A full scale lab , at least 100 v-10 triton engines ( for testing variety of engine oil formulations & levels ) , possibly a dozen technicians and few engineers . Also some precision testing equipment needed to monitor wear properties on numerous engine components . It could get real expensive very quickly , unless we get it published by the engine manufacturer .
Old 06-20-2013, 09:16 PM
96mark8's Avatar
96mark8
96mark8 is offline
Mine burns about 1qt every 1000 miles or so as well and from what i have read on here its seems common/normal. I normally add half a qt at a time when it gets close to the minimum mark on the dip stick but after reading your guys posts maybe i will stop doing that lol.
Old 06-21-2013, 08:25 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Neil, have you seen this thread by Housedad over in the EX forum? Some pretty good info on our PCV valves, with the kind of oil consumption you are seeing it may be the culprit.
https://www.ford-trucks.com/forums/9...cv-valves.html
Old 06-21-2013, 08:36 AM
neilc88's Avatar
neilc88
neilc88 is offline
Thanks for the link. I have not seen this one but will check it out.
Old 04-04-2014, 11:18 PM
98GP's Avatar
98GP
98GP is offline
did you try the PCV valve? Did it fix it?
SoCalAngler
1999 to 2016 Super Duty
05-25-2019 10:48 PM
SilvrT
Modular V10 (6.8l)
13
05-24-2017 08:03 PM
rg200amp
57
03-26-2008 12:14 AM
apache81
Modular V10 (6.8l)
17
09-25-2006 01:40 PM
Studenut65
Modular V10 (6.8l)
16
09-22-2004 08:31 PM
Quick Reply: Low oil in V10
