Low oil in V10 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Low oil in V10
Old 06-20-2013, 11:08 AM
neilc88's Avatar
neilc88 neilc88 is offline
neilc88 is gaining momentum as a positive member of FTE.neilc88 is gaining momentum as a positive member of FTE.
Low oil in V10
Hi guys,
My V10 is starting to use more oil than I realized. 73,000 miles.
It seems to be almost a quart every 1000 miles.
I did my last oil change and got less than 4 quarts out, but put 6 in originally.
Everything is working fine and I never got a low oil pressure indication.
So my question.
Will there not be any engine damage as long as the oil pump intake is still sending oil to the engine??
This makes me sick : to see so little oil come out during the change and I will keep a close eye on it in the future.
P.S. Always use Motorcraft semi-synthetic 5w-20.
Old 06-20-2013, 11:17 AM
cpickner's Avatar
cpickner cpickner is online now
cpickner is gaining momentum as a positive member of FTE.
Your motor should be fine. 4 quarts out of 6 is ok. It is alittle low, but not too bad. Keep checking the level on a regular basis. You may wanna change your PVC valve. If it is clogged, it will increase oil comsumption. Don't ask me how. Some people on here ALOT smarter than me may cime in here.
Have a great day.
Old 06-20-2013, 06:27 PM
Wolfboro's Avatar
Wolfboro Wolfboro is offline
Wolfboro is gaining momentum as a positive member of FTE.
My 2003 behaves the same way . I put 6 qts. in (and add at least 1 qt during the 3k oil change period ) and take out 4-4.5 qts when changing the oil . Also my dip stick is not accurate , it shows half-full mark with 6 qts oil (which is Ford recommendation by the owner's manual).
Ford manual says "do not add if oil level is within the marks" . But at the absence of an accurate dipstick , it is a challenge (even if you re-mark your dipstick for your own "new full mark " . There is always a question about the accurate 5 qts level.
If you did not change your own oil , you would not have a clue about how much oil is coming out . So, relax , you are not alone.
PS.
I wish I could have the answer for the minimum oil level required for proper lubrication . Let me see what I need for that ;
A full scale lab , at least 100 v-10 triton engines ( for testing variety of engine oil formulations & levels ) , possibly a dozen technicians and few engineers . Also some precision testing equipment needed to monitor wear properties on numerous engine components . It could get real expensive very quickly , unless we get it published by the engine manufacturer .
Old 06-20-2013, 10:16 PM
96mark8 96mark8 is offline
96mark8 is starting off with a positive reputation.
Mine burns about 1qt every 1000 miles or so as well and from what i have read on here its seems common/normal. I normally add half a qt at a time when it gets close to the minimum mark on the dip stick but after reading your guys posts maybe i will stop doing that lol.
Old 06-21-2013, 09:25 AM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Neil, have you seen this thread by Housedad over in the EX forum? Some pretty good info on our PCV valves, with the kind of oil consumption you are seeing it may be the culprit.
http://www.ford-trucks.com/forums/98...cv-valves.html
Old 06-21-2013, 09:36 AM
neilc88's Avatar
Thanks for the link. I have not seen this one but will check it out.
Old 04-05-2014, 12:18 AM
98GP 98GP is offline
98GP is starting off with a positive reputation.
Quote:
did you try the PCV valve? Did it fix it?
Excessive oil consumption rock2610d Modular V10 (6.8l) 21 01-08-2016 11:20 AM
First oil change tracyclifton 6.7L Power Stroke Diesel 17 10-19-2015 06:57 AM
Oil Issues NateMack06 Modular V8 (4.6L, 5.4L) 1 04-23-2015 07:52 AM
Oil Capacity and Dipstick Questions ALedbetter1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 03-28-2015 07:17 AM
Rislone Zinc Oil Additive smokersteve 6.0L Power Stroke Diesel 12 01-21-2014 12:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
