Speed sensor-shifting problems - Ford Truck Enthusiasts Forums
Old 06-20-2013, 09:20 AM
tlray tlray is offline
tlray is starting off with a positive reputation.
Hi, New to the site, looks lke a great one. I have a 1997 F350 motorhome with a overdrive auto transmission. The trans. started shifting hard and the light started flashing on the overdrive control and I had no speedo. It even went into neutral, I guess, because I had no gears at all and then it came back to where I had gears. I unplugged it and I had all the gears but it shifts hard with no speedo and overdrive flashing.I replaced the rear end speed sensor and it fixed it, for a while and then it started doing it again. Could I have a bad sensor, could the fluid need changed or I have read that there is a sensor in the transmission also. Sorry this is so long just trying to give as much info as possible. Appreciate any help, going on vacation in the West Virginia mountains in a couple of weeks, hate to loose my tranny.
Old 06-20-2013, 11:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I hate when a tranny gets loose! Then you have to chase it down, bring it back, reinstall it. It is almost as bad as when you lose your trans. Then you have to rebuild it.
Yes, you could have installed a bad sensor. Nothing built by humans is perfect. It is about as likely as winning the Powerball lottery. It can happen, but it isn't likely.
It is MUCH more likely that there is something wrong with either the wiring between the computer and speed sensor or the dash computer which is called the PSOM.
Read this to see how you can read the codes stored in your computer. That is the best way to start to find out what's wrong.
rebuilt transmission flashing O/D light with codes mototrig 1999 - 2003 7.3L Power Stroke Diesel 18 03-22-2016 09:22 AM
4R70W no OD after rebuild RVanPeeren Clutch, Transmission, Differential, Axle & Transfer Case 7 09-06-2014 04:06 PM
1995 E250 strange problem - transmission? DoggoneGA 1968-2013 Full Size Vans 45 07-04-2014 10:23 PM
Overdrive Light Flash azpowerstroke 1994.5 - 1997 7.3L Power Stroke Diesel 6 05-07-2012 11:30 AM
1991 F150 4EOD tires, shifting, speed sensor, speedometer top213 1987 - 1996 F150 & Larger F-Series Trucks 6 10-22-2007 09:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
