239 Ignition Timing - Ford Truck Enthusiasts Forums
239 Ignition Timing
Old 06-20-2013, 08:11 AM
F-100CustomCabTBC's Avatar
F-100CustomCabTBC F-100CustomCabTBC is offline
F-100CustomCabTBC is starting off with a positive reputation.
239 Ignition Timing
Hi,
I am trying to get my 239 OHV up and running. But the mechanic that is going to help me doesn't know anything about Y blocks.
He needs to know the following:
1) Cylinder locations 1-8
2) Cylinder locations on Distributor cap
3) Distirbutor rotation (CW or CCW)
4) Tune Up Specs (points gap, dwell gap, spark plug gap ect.)
And anything else that you think is important that I forgot.
Thank You,
Old 06-20-2013, 09:05 AM
Cubawashere's Avatar
Cubawashere Cubawashere is offline
Cubawashere has a good reputation on FTE.Cubawashere has a good reputation on FTE.
Old 06-20-2013, 04:54 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
Sounds like a good mechanic, and I'm not being sarcastic. It is good that he asks these questions and does not make assumptions.
Cylinder numbering.
So we are on the same page, the water pump is the front, the flywheel is the back, the distributor is the right, the oil pump is the left.
On the right bank, numbered from front to back, 1, 2, 3, 4
On the left bank, numbered from front to back, 5, 6, 7, 8.
Firing order 1-5-4-8-6-3-7-2
The distributor cap probably has a 1 near one of the terminals and that is where #1 should be. From there, follow the firing order, counterclockwise.
I don't remember the tune up specs, but I believe that is typical of any points equipped v8.
For stock cams, valve clearance, .019". About 1/4 turn of the adjuster screw loose from 0 clearance will get you real close.
Old 06-20-2013, 09:43 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Stock cam valve clearance of .019" will work better .
Old 06-20-2013, 10:09 PM
Yes it will. I knew something wasn't right about that when I typed it. I'll correct it. Talk about a brain fart.
Old 06-20-2013, 10:28 PM
46yblock's Avatar
Recently I relayed a little formula provided by Ted Eaton on flywheel weight. Said a rule of thumb is 1 lb flywheel per 10 lbs. vehicular weight. Left out the second zero .
Old 06-22-2013, 09:14 AM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Here is an image that might be helpful.
It was from this thread: http://www.ford-trucks.com/forums/12...lp-please.html
I'm currently putting together my 239 Y-Block. I'm an amateur so I'm going very slow and asking lots of questions. My thread is in my signature.
Here are the distributor specs from the shop manual:
Old 06-24-2013, 10:44 PM
Thank You, That is very helpful!!
Old 07-02-2013, 11:18 AM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
I would recommend getting a shop manual... That is where Harrier got his page of info...
Harrier is rebuilding a '55 239... make sure the specs are the same for a 58, if that is what you are working on.
Old 07-02-2013, 11:22 AM
It's mentioned at the top of the image for 54-59 Ford and 55-57 T-bird
55 239 Yblock help Silver54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 12 02-06-2017 09:40 AM
Plug gap dobenator 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-06-2016 01:06 PM
1954 f100 engine swap bluesalomon 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-22-2016 06:00 PM
advice on 239 starter Emel 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-29-2013 09:10 PM
To gap or to dwell - That is the question Baxtjh 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-07-2010 09:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
