Fuel Pump Driver - Ford Truck Enthusiasts Forums
Fuel Pump Driver
Old 06-20-2013, 07:05 AM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
Fuel Pump Driver
Well this just isnt my month for my truck. Im taking my truck to North Carolina in a couple weeks so ive been checking things over. Ive never had the spare out and didnt want to end up neededing it and have it stuck and not able to drop it, so i dropped it out. Well first the lock cylinder in the bumper that you have to remove to get the rods in to lower the spare was all rusted on the back side and i couldnt get it to turn so i shot it with PB Blaster and let it sit and it did loosen up, but when i pulled it out, i found it was really rusted. THe E clip was broke and the one tab on the lock bent out ward. So im trying to fix that.
The spare dropped out fine, no problem. So i figured i would check the fuel pump driver while i was under there. Holy crap, i cant beleive mine is even still running! The alumnium body is broken in half, with two gapeing cracks, the plastic top peice is just about disconnected from the body of the module. The whole thing is just all corroded.
I will be picking up a new one on my way home from work tonight. Autozone has a Doorman brand one with the standoffs, which ive heard others using as far as the brand goes and not had any issue. So im glad i checked cause that would have been a real vacation bummer being broke down halfway to NC in the middle of the night because of something i could have fixed.
I will post pictures of it when i pull it out tonight.
Old 06-21-2013, 06:44 AM
xjcamaro89's Avatar
Ok got my pump module switched out last night. Mine was junk, i dont know how water and stuff wasnt getting into it and it didnt die already. Here are some pics of the old one.
Rusted, Corroded, Broke. Looks like the corrosion on the underside kept building up and pushing the module away from the frame causing it to buckle and break
Layer of corrosion build up on the under side. I was able to scrape it off with a screw driver.
Another view of how broke it was.
A hole that ate through under the layer of corrosion.
Without any excessive force at all i was able to break the peice in half by hand. Didnt seem to have any evidence of moisture inside though.
And here are some pics of the new one, i cleaned up the cross member and gave it a shot of paint. I actually gave the whole frame everywhere a shot of paint. Makes it look alot cleaner.
All mounted up
You can see the gap between the module and the frame now.
I also scraped off the rust on my spare tire and shot it with a coat of paint. And also my hitch. I also got my lock cylinder fixed with a new E clip and slathered it up with anti-sieze before putting it back in.
The guy who had the truck before my must have never washed this truck or cleaned the under side. Everything has a coat of rust on it. So i try to scrape it off and shoot it with some black paint. Makes it look alot cleaner and nice.
Thanks
Old 06-21-2013, 12:48 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
dang. I remember reading about those modules back when I had my truck, but never understood what all the commotion was
now I see. Talk about some disassimilar corrorsion. I can't believe Ford didn't use an isolator or something to prevent that corrosion.
Old 06-21-2013, 12:51 PM
xjcamaro89's Avatar
Ya you can see in the last picture the new ones come with a rubber isolator to keep the unit from sitting right on the frame.
Can You Get To Your Spare Tire???? pawpaw Ranger & B-Series 57 02-11-2016 04:19 PM
IN DESPERATE NEED ON HELP. BROKE DOWN 450 MILES FROM HOME ON 77 NORTH OUT OF VIRGINIA/NORTH CAROLINA mikefred44 1999 to 2016 Super Duty 12 06-06-2015 10:02 AM
Carolina Beach Benztechnc North Carolina Chapter 6 03-07-2015 07:13 AM
85 F150 wont move whats the problem! captain1997 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 39 10-12-2014 11:03 AM
2010 f350 rust CRACKERJOHN 1999 to 2016 Super Duty 8 04-15-2014 11:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
