2006 F150 Engine Shudder, low speeds with AC on
Old 06-21-2013, 08:06 PM
tonbis's Avatar
tonbis
tonbis is offline
Cool 2006 F150 Engine Shudder, low speeds with AC on
We have a 2006 F150 w/new engine, new everything but transmission and cat. converter. When driving in warm weather with the AC on and at low speeds or idle the engine will knock and want to cut out but you rev and turn off the AC and it stops. Only with AC on. We replaced fuel filter, fan throttle took to dealer and updated the software which it stopped for 3 days and started again today. Really frustrated! Could it have to do with AC compressor or low refrigerant? Please help my husband is at his wits end and I know way more than I ever cared for with truck repair! Thanks.
Old 06-22-2013, 11:33 AM
charz's Avatar
charz
charz is offline
Is the truck equipped with skid plates?
I had a similar issue and it turned out the skid plate under my transfer case was bent upwards and rubbing on the exhaust making it seem like it was knocking and causing excessive vibration to the cab.
Old 06-22-2013, 12:41 PM
tonbis's Avatar
tonbis
tonbis is offline
But would it do that only after the truck had been running for a while and only when the AC is on? I would think with the skid plate rubbing it would do the knocking more often.
Old 06-23-2013, 12:51 AM
charz's Avatar
charz
charz is offline
that's what I thought as well but these motors have a fairly loopy idle.
what happened to me was it would when the idle was loopy it would intermittently make a knocking sound and when I turned on the AC it would vibrate plus it transfered the loopy idle shake to the cab.
check underneath the truck on the passenger side right under the T-Case there's a skid plate and the exhaust is very close to the skid plate, I had bent mine helping out a friend with farm work and bottoming out over a hill and ultimately I had to scrap the plate because I couldn't get it bent out right and even after going crazy with a high speed cutter it still rubbed.
Old 06-25-2013, 08:04 AM
jp4lsu's Avatar
jp4lsu
jp4lsu is offline
It could be something really odd or out of the ordinary like Charz is saying.
Being a new engine and the dealer having checked it over, I wouldn't think it would be spark plugs or Coil Packs going bad.
I had a miss due to bad plugs and it would shudder and vibrate in low RPMs in OD. Changed the plugs and it is perfect.
daniel044
2017+ Super Duty
06-04-2018 11:16 AM
Southfork894x4
06-22-2012 09:45 AM
cbbass123
06-24-2008 01:28 PM
Quick Reply: 2006 F150 Engine Shudder, low speeds with AC on
