2002 7.3 starting problem. - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-19-2013, 09:32 PM
vczar1 vczar1 is offline
vczar1 is starting off with a positive reputation.
Tried to start my Ex today and it tries to start but than sounds like something is grinding, on a 2nd or 3rd try it starts. The sound is similar to if you try to start an already running veh. Any ideas??
Old 06-19-2013, 10:18 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Sounds like the starter is going out to me.
Also, check to make sure the starter bolts are all tight. It's not a frequent problem, but it's also not uncommon for them to back out.
Stewart
Old 06-19-2013, 10:40 PM
Cubawashere's Avatar
Cubawashere Cubawashere is offline
Cubawashere has a good reputation on FTE.Cubawashere has a good reputation on FTE.
I would agree with Stewart, starter sounds like it's toast.... the gear itself, but change out the whole thing and be done with. Also be sure to take off old one prior to picking up new one, as there are two different types for this motor.... a 2 bolt and a 3... most common I've seen are the 2 bolt ones though... also will have the "core" already with you.
Old 06-20-2013, 09:16 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
As per the rest, check the starter bolts, then replace the starter....
On most 2002 trucks, the 2 bolt gear reduction starter is what came stock. If you find a 3 bolt, (longer, heavier, and harder to install) replace it with the 2 bolt gear reduction starter.
weird starter noise. bassranger8722 1999 - 2003 7.3L Power Stroke Diesel 13 05-19-2015 08:01 PM
Batteries Good Still won't Start jprankin 1999 - 2003 7.3L Power Stroke Diesel 22 11-18-2014 07:53 AM
03 won't start Audrey Jean Rose Escape & Escape Hybrid 9 08-07-2014 11:35 AM
02 7.3 straightpipe dumped sounds like has a miss? Imca00 1999 to 2016 Super Duty 1 04-17-2014 05:42 PM
Clicking under dash - no start jpkinard 1999 - 2003 7.3L Power Stroke Diesel 27 09-30-2012 07:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
