1993 Ranger 2.3 Timing belt broke - Ford Truck Enthusiasts Forums
Old 06-19-2013, 07:26 PM
TransplantX TransplantX is offline
TransplantX is starting off with a positive reputation.
Hello all,
My 1993 Ranger 2.3 broke the timing belt running down the highway other day, so I'll be tearing into it tomorrow to replace it. Are there any tips to figuring TDC and all the other timing marks perfectly?
Thanks in advance!
Old 06-20-2013, 01:41 AM
Stinky1 Stinky1 is offline
Stinky1 is starting off with a positive reputation.
I assume that you have a manual. I've never done it on that motor. I've done in on a 2000 Pinto while standing off-camber, in a sand-dune on my buggy and also on several others. On a sand buggy, it can be done in 15 minutes, EZ.
Just line up the marks, give the motor two full turns and verify that the marks line up again. You can, often, start it up in order to verify that it will run, w/o putting all of the covers back on.
A word about your crank nut. It holds the pulley in place and prevents it from turning/moving. All the keyway on the crank does is index the crank to the proper location. The keyway does not prevent the pulley from moving. If the nut is loose, the pulley will move and after 20-50K miles the keyway will be wallowed out and, if you are lucky, the only thing that will be ruined is your pulley. But, likely, the crank's slots will also be messed up. I found this out on a Mazda MPV that somebody had changed the TB on. It started running worse and worse and finally, I had to advance the dizzy as far forward as possible as the crank gear had turned.
Therefore, torque the crank nut to specs.
Need Ford Ranger 2.3L Timing Belt Checked Skyway420 Ranger & B-Series 5 07-22-2016 11:41 AM
Doing a timing belt on a 93, need lots of advice 1998Ranger25L153CID Ranger & B-Series 2 06-12-2014 08:50 AM
Timing belt issues freednighthawk Ranger & B-Series 6 02-03-2014 02:54 PM
08 2.3L Escape drive belt will not stay on Tony2847 Escape & Escape Hybrid 6 08-17-2012 12:59 PM
Broken timing belt DenG Ranger & B-Series 4 08-12-1999 07:00 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
