Fuel tank - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Fuel tank
Old 06-19-2013, 07:23 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
Fuel tank
Does anyone know how many liters/gallons the tank is on a 99 F-350 4x4 dually diesel?
I just went for fuel and it took $170 worth Ive never put that much in before?
Old 06-19-2013, 07:30 PM
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
My long bed F250 holds 38 gals. You should be close to that.
Someone could have replaced the standard tank with a 50 or 60 gal tank. Such as Titan.
We have $3.75 per us gal at the moment.
Old 06-19-2013, 07:38 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is online now
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
29.0 gallons for a short bed, 38.0 gallons for a long bed.
Old 06-19-2013, 08:21 PM
Vinford's Avatar
Thats 144 liters and mine took 131 so I guess it was right.
Ive never put that much in before.
Old 06-19-2013, 11:54 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
i wish mine had the 38 tank, my brothers has it and he can drive for ever before needing fuel, and it fills like i need it ever day.
Old 06-20-2013, 01:56 AM
A/Ox4's Avatar
9 ECHO 1
I have the small tank. I fill up 2-3 times per week.
Old 06-20-2013, 02:51 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Heh, I used to regularly put 34+ gallons in my short bed. Now that I have a long bed I regularly put 40+ gallons in at fill up.
Stewart
Old 06-20-2013, 02:59 AM
A/Ox4's Avatar
9 ECHO 1
Quote:
Stewart
My 10 gallon hat holds approx. 13 gallons.
Old 06-20-2013, 03:09 AM
Stewart_H's Avatar
I run the tank down as low as I can before sucking air, then fill up. And I mean UP...as in up to the opening in the fill tube.
The Ex has a 44 gallon rated tank but I've put more than 44 in it many times.
Stewart
Old 06-20-2013, 12:31 PM
A/Ox4's Avatar
9 ECHO 1
Have you done the tank mods? I hear that adds quite a few gallons as well.
Old 06-20-2013, 12:47 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Harpooning the tank only allows you to fill it COMPLETELY in less time.
The FULL amount is the same either way.
The small vent (not the one in the filler neck) takes care of any air bubble that would be at the top of the tank, but it vents very slowly and carefully to avoid fuel spills.
Top of the neck is top of the neck.
Pop
Old 06-20-2013, 03:02 PM
Stewart_H's Avatar
Most guys don't run their tank down as low as I do. Plus, I fill it up to the same spot, every time, right up to the filler tube opening.
The 2002 didn't have any tank mods done, but my '99, I believe Clay did the in-tank mods when he owned the truck. But like Marv posted, it doesn't add capacity.
Stewart
Old 06-20-2013, 04:03 PM
A/Ox4's Avatar
9 ECHO 1
I think what I'm remembering is it adds capacity between empty to click off if you trim the vent hose thing.
Old 06-20-2013, 10:43 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is online now
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Stewart
Pshaw! It make it quick and easy to use the capacity already there. Why spend 5 minutes trickling in the fuel to get to the top of the neck, and hogging the only #$@&* diesel pump in the process? The OEM long vent tube cuts off the escaping air as the tank fills so the gas pump will shut off, leaving room for vapor as required on a gasser. Same tank in our trucks. Cut off the vent tube (harpoon) and the fuel keeps rocketing in to the top instead of clicking off 2-3 gallons short.
To OP: at least you know your duckbill is tight.
Old 06-21-2013, 12:48 AM
Stewart_H's Avatar
Quote:
As has been posted, that is the benefit of harpooning!
Well, where I get fuel, there's more than one green handled pump. As for the why? I have a very mild case of CDO. It's a lot like OCD but the letters are in the correct order like they're supposed to be.
More like 5, with rare occasions for 6.
Stewart
1997 f350 crew cab 4x4 diesel fuel tanks capacity sand1 1994.5 - 1997 7.3L Power Stroke Diesel 16 08-08-2014 12:32 AM
fuel tank swap smashfoot 1999 to 2016 Super Duty 0 02-06-2014 02:13 PM
1995 f350 fuel tanks size? 2002exPSD 1987 - 1996 F150 & Larger F-Series Trucks 1 02-24-2011 11:50 AM
Fuel tanks leak TurboTuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 50 01-28-2011 09:54 AM
1997 f-350 4x4 diesel fuel tank removal hillbillyk 1987 - 1996 F150 & Larger F-Series Trucks 3 04-22-2006 11:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
