351W to 7.3l PSD information
Hey Zack are you still looking for donor truck? It's not a 4x4 f350, but it has the dash and stuff you might be looking for.
PARTOUT 1996 F250 7.3l Diesel PARTOUT MAKE AN OFFER
Somewhere in the 7.3 thread there is a guy that went from a 460 to a PSD and I know he had to change the cross member. He also said something along the lines of, "If you're going to do this swap, you MUST have a complete donor truck."
That being said, a PSD Bronco would be bad ***. I've seen them before under the "Super Bronco" badge. Looks like Super Duty but says Bronco instead.
FWIW to rebuild a 7.3 it can be done for around 3-8k depending on what all your having done or if you do the work yourself it can be cheaper, theres a couple options, you could do this
Riffraff Diesel: Ford Overhaul Kit
or check out swamps diesel performance with there assembled engines
Assembled Performance Engines - Swamp's Diesel Performance
