Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Rear gear swap
Old 06-19-2013, 03:10 PM
imabass's Avatar
imabass
imabass is offline
Rear gear swap
I have Ford L8000, 7.8 Turbo (non intercooler), with Rockwell SQ-100P rear diff with 6.14 gears. Door tag rating is 39,000#. It has the FS-5005 5 Speed transmission. I have 11R22.5 tires.
With the final gear ratio of 1.0 and rear end gear at 6.14, the estimated top speed is about 50 mph at 2500 RPM.
I have done some calc and swapping the rear end gear to 4.88 will increase that speed to 63 MPH.
I have done several gear swaps in the past in a race car so doing the swap is not a problem.
Thought? Where is a good supplier for gears?
Old 06-19-2013, 07:37 PM
80broncoman's Avatar
80broncoman
80broncoman is offline
I just got a air ride axle swapped into my F-700.
My gears were changed from a 4.10 to 3.58 . I bought a used set of gears from Anderson bros in Portland OR. A lot of these big truck axles look like a over sized 9 inch. Much simpler than you might think.
I also not over look ebay as well. and don't forget to do some homework to make sure there isn't a carrier break between those two ratios for your rear end.
weekendfarmer
13
08-31-2018 02:55 PM
jumpinon35s
05-15-2015 11:48 AM
69taposer
08-04-2012 09:28 AM
Mick1930
09-06-2009 08:13 AM
Aero-fan
Aerostar
19
05-13-2008 02:20 AM
Quick Reply: Rear gear swap
