had truck towed to Ford. they're saying - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-19-2013, 03:22 PM
rolltide3006 rolltide3006 is offline
rolltide3006 is starting off with a positive reputation.
Got fed up with this no start. Checked all the regular culprits, nothing. Had it towed to the dealership and they're saying the pcm is putting out codes that a gas engine does. So I guess I have a bad pcm? Don't really have the funds right now for apcm. Can I get it reflashed?
Old 06-19-2013, 03:47 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Did you re-flash the PCM with a programmer or something? Maybe selected the wrong option! Yes, Ford can re-flash it or at least they have the capability if anyone remembers how to do it.
Old 06-19-2013, 04:00 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
PCM's are like 200 bucks now ....Hell.... I just bought one for 50 bucks about 1 month ago.....Jody @ Dptuner can flash whatever you want on your existing one a reasonable price as well .... What is your Code ?http://www.thedieselstop.com/faq/949.../pcmcodes.php3 Are you sure it is not IDM codes ?
Old 06-19-2013, 04:45 PM
A new IDM was one of the many parts I threw on the truck since it quit working. I never flashed the PCM. I do have a chip though. Do PCMs ever break so bad that they can't be flashed? Not at home now so don't know my code.
Old 06-19-2013, 05:20 PM
blageurt's Avatar
No they do not Break so to speak ...but they can have electronic issues...I am not an electronics expert BUT I have hired a few guys that were computer geeks and they solved the problem...BAsicallly the had a old scholl occilscope nd a wiring diagram I provided and in 15 minutes they figured it out...I paid them Well.....thats what I would do .....That being said I have 3 140 V Idms and 4 PCM's ready to Install in my truck Right Now ...because I am a Mechanical Guy...but I do have electronic geeks on the Payroll.......
Old 06-19-2013, 09:27 PM
nomad221's Avatar
nomad221 nomad221 is offline
nomad221 is starting off with a positive reputation.
Quote:
Who is the company ?
Old 06-19-2013, 09:46 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Did you 'no start' start with the chip install?
Old 06-22-2013, 03:17 PM
Yes Glenn I did remove the chip and it still wouldn't start. Got a little more info from ford. They said the computer threw like 10+ pages of codes.
Old 06-22-2013, 03:22 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
If a PCM shows more than 5-7 codes then 9 times out of ten its a bad PCM
Old 06-22-2013, 03:23 PM
As far as getting it reflashed has anyone done that. Who does it/how much?
Old 06-22-2013, 03:24 PM
fordpride's Avatar
If its bad a flash isn't going to help
Old 06-22-2013, 05:52 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Python Injection is a pretty good outfit for PCM repair. But if the dealer can talk to it with the scanner it may not need repair.
Old 06-22-2013, 07:47 PM
Pjwoolw are you saying the dealership can reflash it?
Old 06-22-2013, 07:55 PM
Ford4Life7.3's Avatar
Ford4Life7.3 Ford4Life7.3 is offline
Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.
yes
10char
Old 06-24-2013, 04:27 PM
Found one in a junkyard. It's in a 97 automatic superduty. Would it work?
6.8L V10 Ignition Problem rocknsoul Excursion - King of SUVs 24 05-28-2014 09:14 AM
Used Bronco bucket seats, red Wyowanderer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 04-29-2014 06:33 PM
bed caps Jarryd 1987 - 1996 F150 & Larger F-Series Trucks 4 11-24-2013 07:50 PM
Which Is the Right PCM (Cardone? Others?) JohnLMiller 1987 - 1996 F150 & Larger F-Series Trucks 0 07-24-2013 12:27 PM
Grip force clutch on ebay ? DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-09-2013 08:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
