had truck towed to Ford. they're saying - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-24-2013, 05:14 PM
rolltide3006 rolltide3006 is offline
rolltide3006 is starting off with a positive reputation.
Talked to Ford they said the part number is for mine is f7tz12a650sb. Going to call the yard tomorrow to see if they will give me the part number off the superduty or vin so I can find out from ford.
Old 06-24-2013, 07:20 PM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
It should unless it is from a California truck....
Old 06-24-2013, 07:29 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
I have to assume this is your sig truck that your working on. If so and it's a ZF5 like your sig says, I wouldn't bother with an auto PCM. It will start the truck, but you will get that horrible romp on start up that auto trucks get with bad range selectors and the PCM will not automatically fuel a little when you start engaging the clutch like a manual PCM does.
Old 06-24-2013, 07:49 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
What about with his chip burnt for the manual? Will it over ride the auto PCM?
Old 06-24-2013, 08:43 PM
Quote:
Yes it will override and run correctly with the chip installed. It's not terribly hard to find manual PCMs though, so personally I'd put a manual PCM back in it.
Old 06-24-2013, 10:01 PM
Tight on money right now so might just have to go with the automatic one from the junkyard for $200 just to get the truck running so I can get it from the dealership. Found one on ebay for $473. Rockout had some for $117 but are sold out now. Wish I could find a remand for around $250
6.8L V10 Ignition Problem rocknsoul Excursion - King of SUVs 24 05-28-2014 09:14 AM
Used Bronco bucket seats, red Wyowanderer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 04-29-2014 06:33 PM
bed caps Jarryd 1987 - 1996 F150 & Larger F-Series Trucks 4 11-24-2013 07:50 PM
Which Is the Right PCM (Cardone? Others?) JohnLMiller 1987 - 1996 F150 & Larger F-Series Trucks 0 07-24-2013 12:27 PM
Grip force clutch on ebay ? DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-09-2013 08:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
