Need opinions on unknown vibration
Just to update the thread. I was able to fix the issue. My rear u-joint was about to fall apart. and the Pinion Yoke was loose. I tightened it back down to spec, and replaced the U-joint. No more vibrations...Nice and smooth. Ran her up to 75 mph and was smoother than my Jeep lol. I did check the driveshaft as well. It was straight as an arrow. I still will replace the double cardan U-joints as well. Thanks everyone for your thoughts and opinions.
Haha, those look like how mine were last year. I was hearing some squealing but not all the time. Didn't have a vibration though but when I went to check the driveshaft (specifically the double cardon joint), dust came out of one of the U-Joints at the cardon joint. I ended up having to replace the double cardon joint too because it was missing a roller pin and I know that would only lead to fun soon on down the road.
Hmm I don't know much about the linkage for the 4wd or the lights. I'm assuming you have checked the bulbs and they are good already. Do you have manual 4WD or auto? I know when I had to take my transfer case down and mess with the linkage stuff (going to the 4wd shifter) it didn't look like there was much adjusting I could do with any of it. I wasn't really paying too much attention to that though because my goal was replacing the clutch/slave cylinder in the transmission when I was taking that off.
I have the manual shift 4wd...When the lever is in 2wd...the front axle is still engaged. There is no engagement feel between 2wd and 4hi...Like my Jeep, When I pull the lever from 2hi to 4hi...you feel that lock. If understand what Im saying. I dont have that in my Bronco...but I do when I go to 4lo. And It is very easy for it to pop out out of 4wheel and into a "neutral". One of the main reasons I dont wheel it.
Hmm are you 100% sure that its put in 2 hi? If the front driveshaft is still spinning, I'm pretty sure it's not out of 4wd. I know it's kinda a pain to get in and out of 4 hi from nuetral/2wd on my shifter. You have to press down on the lever and push it down to 2wd. It should make a click. it takes me a few times going from 4hi to 2hi to get it back in but I can always get it. I would check the fluid of the transfer case too and make sure it's red and has no metal particles in it. I changed my transfer case fluid last year and it was super dirty. I would highly recommend changing it if you have never done it.
I just leave my front driveline off, so that the front wheels don't get any power. As for fluid I put gear oil in mine... I think you are able to use either light gear oil OR Type F. Whatever suits your fancy.
Ah, I don't know anything about Borg Warner stuff. I want to eventually put the NP 205 case in my 78. It's a part time gear drivven and the cast iron ones are next to bullet proof. If I really go crazy I would do the 203/205 doubler but I don't have a need for that much crawling power yet.
#28
It sounds like the NP 205 would be super heavy if its cast iron. Maybe not though. I know mine wasn't too bad, I was easily able to lift it up and down full of fluid when I needed to get to the slave cylinder in the transmission.
#29
#30
improvement54
30
12-13-2006 11:31 AM
