Advice needed: 1977 F250 cab onto 1984 chassis - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Old 06-19-2013, 04:43 AM
J1MB0B J1MB0B is offline
J1MB0B is starting off with a positive reputation.
I'm looking to put the cab and bed from a 1977 F250 onto a 1984 F250 4x4 chassis with a 6.9 idi diesel engine and a 4 speed trans.
Both trucks are extended cabs and in good running/driving condition.
I know I will need to put in the works for the clutch pedal and do something with the fuel tanks/lines. Maybe do some fab work to get things like cab mounts to line up. Anything else major that I'm not seeing?
The only real issue I am worried about is electrical. What should I be thinking about here?
Old 09-03-2013, 03:09 PM
merc2dogs merc2dogs is offline
merc2dogs is starting off with a positive reputation.
Can't provide any info, but I'm looking into doing almost the exact opposite, 84 cab/box onto earlier 4x4 chassis, so I'll be watching this.
Old 09-03-2013, 07:53 PM
fordman75 fordman75 is online now
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
The 80's trucks have the engine set back farther. So you'll probably be in for some firewall modifications.
I believe the 84 has a wider frame in the back then the 77 does. But I'm not sure on that.
You'll probably have to modify all the body mounts, steering hook up.
I've learned from my 54 project to expect to have to change or modify much more then you were originally thinking you'd have to.
Old 09-04-2013, 11:48 AM
Quote:
That's something I have learned too. Too many swaps to count, but most of mine have been jeeps, early broncos, and street cars, My f150 experience has been limited to axle/engine/transmission swaps, and an occasional same year cab or body. Didn't realize when I posted that this thread was a couple months old....
RE-BOLTING CAB ONTO CHASSIS mgerdau 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-03-2016 10:05 AM
Will a 1967-72 front clip and cab bolt onto a 1978 f250 4x4 chassis countrydriven 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-14-2015 02:31 AM
1977 f250 frontend on a 1968 f100 HELP John Rapp 1967 - 1972 F-100 & Larger F-Series Trucks 21 12-04-2015 03:14 PM
84 vac line tn1977 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-30-2015 06:44 PM
help with my f350 srisher 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-26-2015 08:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
