Way too much transfer case fluid - Ford Truck Enthusiasts Forums
Old 06-18-2013, 10:05 PM
bowkill's Avatar
bowkill bowkill is offline
bowkill is starting off with a positive reputation.
Today I was changing rear diff and transfer case fluid. Rear diff change was no problem. While waiting for the RTV to set I went to change the transfer case fluid. I moved the drain pan under the transfer case and started to take off the fill plug, which was not very tight at all. Good recommendation on another FTE thread to make sure the fill plug isn't frozen before draining.
I pull the fill plug and I'm guessing 1/2 qt or more fluid comes out. Not expecting much fluid to come out it goes everywhere. There was enough head pressure to shoot it past the drain pan.
So my question is where did it come from? I lost all my truck records and can't remember when or where I had it changed last. The design of the transfer case would make it very tough to overfill with out making a huge mess.
Do you think the transmission could be leaking into the transfer case? Not sure if this possible. I checked the transmission level and it was a little low.
Truck is 2004 5.4 SCREW 4x4 with 137K.
Old 06-19-2013, 04:04 PM
skunkoffroad skunkoffroad is offline
skunkoffroad is starting off with a positive reputation.
On a lot of designs the transmission can leak into the transfer case. I'm not sure if this is one of them or not.
Old 06-19-2013, 07:14 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
The tranny can definitely leak into the transfer case. Looks like its time to take them apart
Old 06-19-2013, 07:35 PM
bowkill's Avatar
Apparently this is a known problem. Put some Lucas Transmission leak stop in. Hopefully this will fix it. I doubt it but worth a try. I guess the transfer case can only hold so much fluid and then it will start to leak. Looks to be about $400 to replace the seal.
http://www.ford-trucks.com/forums/10...sfer-case.html
transmission fluid leaking into transfer case problem??? - Ford F150 Forum - Community of Ford Truck Fans
Old 06-23-2013, 11:35 AM
dakotarider's Avatar
dakotarider dakotarider is offline
dakotarider is gaining momentum as a positive member of FTE.
Bowkill, I took my 04 in for a trans fluid change (102,000 mi) and it had the same thing. Trans was 2 qts low, T-case 2 qts hi. They pulled it, replaced the seal and reinstalled. In all, it was $527.05. Ouch! Also, when they pulled the drive shaft, the rear pinion seal leaked. This is also a known issue.
Overfilled transfercase or leaking transmission output seal Byoung Oh 1999 to 2016 Super Duty 10 03-23-2016 07:20 AM
Transfer case fluid and belt change f250mtnbikr 1999 to 2016 Super Duty 0 05-15-2015 10:26 AM
Changing Drive-Train Fluids cber Explorer, Sport Trac, Mountaineer & Aviator 2 09-13-2014 10:09 PM
How to: Transfer Case Fluid Change 97ExpGuy 1997-2006 Expedition & Navigator 35 01-01-2012 01:22 PM
Overfilled Transfer Case? AMG-SM 1999 - 2003 7.3L Power Stroke Diesel 5 08-22-2011 11:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
