6.0 E350 Mechanic in Reno? Sacramento?
Hi All,
The time has come where I need to replace the head gasket and EGR on my 05 E350, and I'm looking for a good mechanic in the Reno area or in the Sacramento area. Any help would be great....but I'm looking for a mechanic who understands these engines and their nuances.
Thanks in advance.
Thanks in advance.
I had a local guy do a few tests on it, and that was the conclusion that they came to. New head gasket. The engine is sucking coolant....which started the investigation, then there's a test they performed that they felt was accurate.
I'm not as educated on this as you are....in fact my knowledge may fit into your little pinky....so thanks for your insights.
I did have a time when I re-filled the coolant to the cold temp line because it was a few gallons low (which seems like a lot) that I had liquid coming out from somewhere inside the driver front wheel well. Other than that incident, the coolant is just going somewhere ( no obvious leaks). I use a scan guage and the engine water temp seems to be where it should be 198 -213 (driving up hill in heat).
Any ideas??
Any ideas??
I know of a very good mechanic in the Carson City area. He knows the 6.0 inside and out and has a reasonable hourly charge. Trust me on this one... He does side work on weekends at a reduced hourly charge, I think $65/hr.
If you are interested, send me a pm and I will hook you up with him. He can also assist you with a proper diagnosis. He is very busy lately, however I think it would be worth a try to lock him in for your job. I do know that most 6.0 mechanics really hate working on vans, at least that is what I have heard from them.
Let me know, Tim
Let me know, Tim
Click on link for TSB.
https://www.ford-trucks.com/tsb/tsb.php/m-FORD
Or this might help
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
Or this might help
FORD TSB's (technical service bulletins)
Or this might help
Or this might help
Let me know, Tim
Let me know, Tim
Thanks for the offer.
1. Article says "Fill to MIN fluid levels line in degas bottle" . My degas has only one line and it's called "Cold Fluid Line". No "MIN", and no "MAX". Any suggestions?
2. On a 05 E350 6.0L , can I check the EGR valve for deposits at home? Or does that require taking it to a shop?
Thanks for all your help!!
