Recommendation for under bed gas tank
I sold the 55 and picked up an 80% done 56 small window. One of the projects I am doing is relocating fuel tank from cab to under the bed. Looking for recommendation here from those that have done this. i am leaning towards the Mid-Fifty kit that mounts to stock cross member, has the screw on trap door and uses the door in the wood bed. Am I way off basse?
on
Vinny,
here's the way a lot of us have goner
INSTALLING A MID-60's Mustang Tank in a '53 F-100 truck
you can also check the sticky at the top of the forum for some other tank options...
https://www.ford-trucks.com/forums/1...s-how-tos.html
later
John
later
John
There are lots of options.
The first step is deciding what type of gauge you are using as it willhelp to have the gauge match the fuel sender in the tank; GM to GM, Ford to Ford, aftermarket to aftermarket, etc.
2nd step is to decide where you want your fuel filler hose to be; left side, right side, bed floor.....
The Mustang tank is a popular option. For the Mustang tank the most common place for the fuel filler is through the bed floor.
Full sized Bronco tank has been done a number of times (do a search for RandyJack for a great thread on it) The filler neck will come out on the drivers side of the truck (Randy cut a fuel door into his fender)
The full sized Blazer/Suburban tank is also popular. The filler nekc comes out towards the passenger side for this tank (I'm using it and went with a chrome marine style filler pipe in the right rear fender)
I've also heard tell of some Jeep tanks, Mitsubishi Montero tanks, aftermarket, etc
The sky's the limit
Bobby
The sky's the limit
Bobby
Mid Fifty Tank
Vin Man,
I used the Mid Fifty step down tank that you didn't have to remove the crossmember and it was easy install.
Because I am going to be doing a lot of long distance travelling with my truck I decided to spend the money to go new and that one looked like it would give me the best fit for what I wanted.
The pop top filler cap is great as you don't have to unscrew the cap to fill just put the nozzle down into it, easy peezy. At the time I did it they were a 20 gallon tank but I see they are a 19 gallon now, and there are a lot more door options for in the bed.
Also went with new VDO gauges and tank sender, they all work great.
Good luck, perks56 (Kevin)
If u go mustang it depends on ur setup and how u go about installing the tank. I wanted my tank as high as possible while still maintaining as much of the crossmember as possible. I cut my crossmember in half length wise, welded in some square tubing to give it back the strength i removed. and theb built a support structure to hang the mustang fuel tank from.
The following users liked this post:
__________________________________________________ __
48 Ford F1 - Darkside
46 Ford Tudor - Street rod
"Happiness - 3 pedals and a 5 speed"
Edit: Are you running outside the frame rails and around the coil springs in the rear perhaps?
