Ford 1barrel on my 57 f100 272 - Ford Truck Enthusiasts Forums
Old 06-18-2013, 12:42 PM
truckpastor truckpastor is offline
truckpastor is starting off with a positive reputation.
Thought I'd ask if anyone has heard of the 272 coming with a 1barrel carb set up. I seem to have that setup but can't find info about the carb/rebuilding it. Carb seems small for a v8
Old 06-18-2013, 12:50 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
I doubt you have a 1V carb, they were never used on any V8 that I know of. What makes you think it is a 1V?
Old 06-18-2013, 01:58 PM
I think I'm the bonehead of the month. It has the look of a 1 bbl due to air horn but I looked down it and i see two fuel holes/nozzles
Old 06-19-2013, 04:22 PM
hiball3985's Avatar
Quote:
That would make sense that it is a 2V, we all make mistakes at times.
Old 06-19-2013, 04:31 PM
I think I've found out which carb I have...says Ford USA on it but I believe it to really be a Holley AA-1 \ aka Holley 94?
anyone have anything good\bad to say about this carb? I'm trying to restore to stock conditions Or I'd just drop a 4bbl intake and forget it
Old 06-22-2013, 08:20 PM
NONclow NONclow is offline
NONclow is starting off with a positive reputation.
It depends on how you run it. Regular cruising/fair mileage the stock 94 works fine, there are tons of parts for them. I've got three of 'em on an Offy manifold on my 292 (not stock). A 4bbl intake on a 272......what heads are on it?...stock cam?....it would work, only with a very small carb, say a 365/390 cfm. In my early Y-block days..... 292, tired heads, bird catcher 4bbl intake (pre '57 ECZ-9425-A) with adapter plate, 750cfm Holley!! NO midrange! Idled great, wide open, pulled....ok. bought another 292 with late model Holley flange (ECZ-9425-B) manifold, AND a 390cfm Holley.
All in all, 94's are great simple carbs.... when rebuilt
Old 06-25-2013, 06:32 PM
Everything else is stock so ill rebuild it...no concerned with high performance anyways...thanks for the input
Distributor Question Textile302 1957 - 1960 F100 & Larger F-Series Trucks 7 04-01-2015 02:07 PM
Changing to a 4-barrel Carb. Jag Red 54 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 14 11-06-2014 02:48 PM
Carb replacement sweetlou1 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 03-17-2013 09:18 PM
1956 Ford F 350 carb help BrentASmith 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-15-2012 11:51 AM
272 y blcok performance rebuild help!! lawdogg1 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 03-12-2011 12:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
