74 2wd rack and pinion help
hey guys i have a 1974 2 wheel drive short bed f-100 that i have done a 12 valve cummins swap in, i need to convert the steering to rack and pinion to make every thing work and gain the clearance i need for the oil pan. I'm not having any luck trying to find a kit can any one help??
You can try swapping a rack and pinion out of a mustang or a crown vic. Other than that I'm at a loss.
thanks i have been racking my brain as to what to do with it, its been looking like im going to have to build a custom one i have 54 and a half inchs in between my spindles every thing i have found has been about 10 inches too long. whats the thoughts about cutting a bigger rack and pinion down?
I concur with co425.. a CV R&P but you're gonna have a major issue with bumpsteer because the tie rods and I-beams will be swinging different arcs. You'll either need to convert the front end as a system or modify the the oil pan to make it work. I would do the latter.... it's a matter of cutting and welding your way out of this predicament.
on
Well its been a year now but making progress, I have flipped and criss crossed my spindles, and have built in the rack and pinion out of a 2003 ram 3500 Cummins. So far everything is looking good and my angles are matching up, it's worth a try if not it's getting air bags or ifs front end conversion. I don't have picture yet but I'll get some asap.
on
With those Twin beams suspensions and rack n pinion, what about fitting each tie rod to the opposite side of the rack?
To give them the same or similar swing as the twin beams have. for that matter, what about an idler arm setup and crossing the tie rods that way... Probably wouldn't work with a rack, unless the rack is engineered to cross the beams
Hey blue04.5 I'm still around, I don't have any pictures of it on the truck yet I'll be able to get some when I get home from my hitch at work, still in fabing stage, how ever I am getting close. I'll get some pictures when I get home and get them downloaded.
f100today
01-05-2014 12:32 PM
natedawgg94
13
06-12-2009 08:10 AM
Almost_A_Merc
04-14-2005 09:25 AM
