edelbrock help? - Ford Truck Enthusiasts Forums
edelbrock help?
Old 06-17-2013, 09:25 PM
XTfx4 XTfx4 is offline
XTfx4 is starting off with a positive reputation.
edelbrock help?
Hey guys trying to figure out my carb. situation. Don't know much about them. Anyways I have a 79 ford w/a 400 , edelbrock egr intake topped with a edelbrock 1405 non- egr carb? There are some spacers and plates one of which has a spot to bolt on an egr valve? This plate has 4 holes in it and is about 1 in. thick . However my egr that was attached to it has never been hooked up . There are no other emissions stuff on the truck , should i just do away with the plates and spacers and the egr itself or what? Thanks guys for any info or help.
Old 06-18-2013, 07:04 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Sometimes the EGR valve can alloy you to run a little more timing without part throttle detonation. You can remove it if you don't plan on using it. just be sure that the EGR port on top of the intake will be sealed without the EGR plate on there. Sometimes, they are offset a litle and the standard spacer will not cover it. Not sure how the Edelbrock is configured.
EGR plate delete on a 1979 7.5l 460 bullnose1985 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 08-17-2015 12:53 PM
1977 460 EGR spacer plate 77truck460 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-18-2014 01:36 PM
Performer 3766 on 460. Need EGR plate santeeford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-12-2012 01:52 PM
1973 351w intake and carb help derk001 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 25 08-09-2012 06:49 AM
Carb, spacer plate, & EGR plate. . .what order??? atomicjoe23 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 03-10-2010 02:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
