05 f150 rumble - Ford Truck Enthusiasts Forums
05 f150 rumble
Old 06-17-2013, 08:16 PM
nadieselbogger85 nadieselbogger85 is offline
nadieselbogger85 is starting off with a positive reputation.
05 f150 rumble
Hey guys my 05 f150 5.4 with 76,000 has a weird rumble at idle, I don't think its a miss and there's no codes and when I put it in park it goes away or if the idle changes just a little you don't feel it. And you feel it through the brake pedal the most its not real bad butb enough to bother me. Do any of you guys have any ideas
Old 06-19-2013, 09:55 AM
No one has ever come across this same prob?
Old 06-23-2013, 05:14 AM
Even turning on the ac is enough to make it go away
Old 06-23-2013, 10:48 AM
Nalb1221's Avatar
Nalb1221 Nalb1221 is offline
Nalb1221 is starting off with a positive reputation.
Have you ever cleaned the massairflow sensor or throttle body? Does you rpms jump around at idle? If turning on the ac fixes it,its because the ad kicks the idle up. I'm betting cleaning those I mentioned will help.
Old 06-23-2013, 04:21 PM
Yea I will try that and no it doesn't jump around at idle
Old 06-25-2013, 12:31 PM
Well cleaned the mass air flow sensor last night and cleaned the throttle body still has the rumble
2004 exped noise when turning gogreenwave 1997-2006 Expedition & Navigator 2 07-30-2014 06:54 AM
Truck feels like Rumble Stripon road sammydiesel 1999 - 2003 7.3L Power Stroke Diesel 13 12-10-2009 05:42 PM
heat shield rattle??? tmoney67 2004 - 2008 F150 8 03-10-2006 07:34 AM
04/04 6.0 X Drivetrain rumble on acceleration DFW1 Excursion - King of SUVs 3 01-25-2004 10:56 PM
'79 Ford 460 exhaust system. What you think? patsplace Exhaust Systems 7 12-31-2002 11:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
