upper water pump fitting
You can buy one here:
http://www.dieselsite.com/search.asp...er+pump+outlet, and Im pretty sure RiffRaf also has it.
Hello sir! I've been dying to post here all day to help but there were complications...
The part you are looking for is the "thermostat housing" for the 94-97 7.3L's. It's more commonly known by that name so you should have better luck finding it than as the upper water neck.
A more specific part number is the: RH110 by Motorcraft - you can purchase one at your local Ford dealership I believe.
I hope this helps!
I hope this helps!
I hope this helps!
I hope this helps!
Consider one of these: Thermostat Housing Ring as well. If your only problem with the existing one is a bent flange, this may make it right.
That may be a generic pic; those o-rings may not be included in the kit for the OBS. I'll try to remember to check the kit I have sitting in the basement when I get home tonight.
