engine number help needed
I have the same question on another thread and numbers dummy is the man with answers. However he has no answered mine either as of yet.
I'll give it a try
C3AE indicates a 1963 full size engine
6015 has to do with the engine assembly
In 1963 I think the V8 was a 351 Windsor
There may also be a date code it was cast like " 3C7" meaning 1963 March(3) 7th
Numbers Dummy (Bill) will do much better
Wow it took me so long to type that Old broke Prospector answered it
Scott
I'll give it a try
Scott
Originally Posted by scottlathrop
C3AE indicates a 1963 full size engine.
In 1963 I think the V8 was a 351 Windsor.
262 I-6 available in 1963/64, but this is a truck engine only, not installed in cars, so the casting number prefix will have a T as the 3rd digit.
351W introduced in 1969 Ford/Merc Passenger Cars, first installed in 1975 Econolines, 1981 F150/350's & Bronco's.
Casting numbers found on engine blocks are foundry marks, cannot be decoded in most cases.
numberdummy
I knew the numberdummy would get to the bottom of that, Thanks for not making me look as bad as my answer.
Bill, I changed the starter the other day and got the numbers from underneath. They are from my 66 Flareside and the replaced engine.
The hidden numbers are EOAE D3C00 4B20.
I was told at the parts store' it appears to be a 302 from a 1980 bronco however you mentioned (without the numbers) it could be a Windsor. The Manifold is an Edlebrook so I'm still having trouble identifying the engine
Could you or someone confirm from this info what it actually is. Thanks in advance
Scott
Scott
Hey you guys are Great. The best part is that with all the knowlege you guys have, you still have the patience to answer green questions. that's good because Im sure Ill have more.
l dont want to butcher the 65 to make the 64 223 fit. i suppose the search is on for an engine and tranny again. The 64 still has a functional drive train so it may have to tear up the organ donor card.
Thanks, Dennis
Thanks, Dennis
If anyone in Southern California has an engine and trans and willing to get rid of it let me know.
