Whats this for on my rear axle E150 1989
many automakers install such things in what appear to be random places, with the intent of preventing some strange vibration that may occur without it.
another possibility is that someone installed it as a jacking point so tire shops won't damage the diff cover when jacking from that point, as they might if they jack there without the extra component.
in any case, posting a pic would help us identify it
F19Z-4A263-A (replaced F1UZ-4A263-A, E99Z-4A263-A & E7UZ-4A263-A) .. Rear Axle Drive Line Vibration Damper ~ 1987/91 E150 4.9L/5.0L / 1989 Aerostar from 10/88 / 1990/97 Aerostar.
Late model AOD's are electronically controlled, dunno if you can install a floor shifter. "Dog house" (engine cover) takes up most of the space where a shift lever could poke thru the floor.
Last edited by NumberDummy; 06-18-2013 at 02:07 PM. Reason: Typo: I original typed "O with a circle around it."
sounds like an AOD. p-r-n-(circled d)-d-1 - AKA 4-3-1 shifter. this is typical of a non-computer-controlled AOD, if i remember right.
as for the possibility of a floor shift, its possible in theory to have the shifter anywhere you want, even up on the roof, but you would have to make the right linkages to make that happen. step 1 is to measure the floor shifter you like and see where it would end up on the floor around the doghouse, and decide if thats something you want. then you just have to fabricate the linkage from there to the tranny
pancake52
04-22-2017 10:46 AM
leslane
10-05-2010 07:46 PM
