95 7.3 shut off like a switch, wont restart - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-16-2013, 08:04 PM
acf6's Avatar
acf6 acf6 is online now
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
We were headed to a truck meet friday night when one of my buddies in the convoy with his 95 F350 7.3 just died pulling upto a red light like he hit a switch, no stumbling/surging/nothing. Cranks, but doesnt restart. That night we tried diagnosing it with like 10 guys but we had no luck, had to tow it home. We unplugged the ICP sensor then as well, and it was actually melted, but still wont restart.
I dont know much history of the truck but it has 273k miles and he installed new injectors a few hundred miles ago. Weve had it hooked up to either my truck or my buddies cummins charging it while trying to start it.
-We triple checked every fuse under the dash, and the hood.
-Horn worked, so we swapped that relay with the IDM and PCM relays and those were both good.
-Tested GPR, working.
-No smoke coming out exhaust
-Wait to start light comes on and takes probably 15 seconds to go off.
-Tach does not move when cranking
-Fuel bowl is filling up
-Cleared all the codes, and the only one left is P1280
-Hooked my scangauge up to it and read ICP, while cranking first try was 0, second was 2400, third was 0....
-Switched from front to rear fuel tank, still nothing...
-UVCH were both plugged in
Hes short on money because hes a senior in high school and bought this truck from a farmer for like $2000, and has been putting a bunch of money into it fixing necessary items. Swapped the CPS today, no change. Theyre going to replace the ICP sensor tomorrow after work. The only 7.3 around is a super duty so we dont want to pull the fender off just to see if we can swap IDMs and determine if thats it. Any ideas? No idea what they did when the injectors went in, if that could be affecting something
Old 06-16-2013, 08:13 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
With no tac movement I'd start looking at the CPS wiring
Old 06-16-2013, 08:15 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
I would start with a new cps from ford, sounds like you need a new icp sensor also. The idm from a 7.3 super duty will work on his too, no need to pull the fender off to get to it either. It just unbolts from the fender and its free.
Old 06-16-2013, 08:18 PM
acf6's Avatar
Thanks guys, he said the CPS was only like $16 so it probably was from napa. I know the IDM on the OBS is on the inside, but on the super duty isnt it behind the fender?
Old 06-16-2013, 08:20 PM
fordpride's Avatar
I'd try a fird or IH CPS. The ones from parts stores are known to be dead out the box
Old 06-16-2013, 08:21 PM
fordpride's Avatar
To get to the sd idm you have to remove the inner fender
Old 06-17-2013, 07:15 PM
acf6's Avatar
Alright, we put in a Ford CPS and ICP sensor. ICP sensor wiring looks good. Still nothing. Whats next...swap IDMs? IPR?
Old 06-17-2013, 08:23 PM
fordpride's Avatar
Quote:
Are get it put on a AE
To start a psd you need
10.5 v
125 RPM
500psi HPO
15psi fuel pressure
Old 07-25-2013, 06:06 PM
jcass29 jcass29 is offline
jcass29 is starting off with a positive reputation.
I don't mean to hi jack your thread but I have a 96 f250 7.3 turbo. It has shut off on me a hand full of times just like you turn the ignition off no stumbling, surging, or anything but it has always started right back up. Recently it shut off on me and it took a good minute to start back up. Today coming home it shut off while driving and would not restart I ran the battery's down and had to have a jump. once I got the jump it fired right up and I drove it home, now I'm scratching my head. Any help would be appreciated.
Old 07-25-2013, 06:07 PM
acf6's Avatar
With this truck it happened to be the HPOP went bad
Old 07-25-2013, 06:10 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
Get a CPS (cam position sensor) from IH or Ford. Stay away from the parts store ones. The sensor is just above and to the left of the crankshaft pulley on the front of the engine. It's easier to get at from below. Takes a 10mm wrench and about 5 minutes to change.
Old 07-25-2013, 07:05 PM
Yep, I just had the codes read and I got CPS code and Low volts code which I attribute to running the battery's low trying to start it. Thanks
Old 07-25-2013, 08:31 PM
fordpride's Avatar
Yup get a CPS.
That code really doesn't mean anything. These trucks will set a CPS code with extended cranking
Old 07-25-2013, 09:18 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
Quote:
How did you find that out
intermittent stalling at acceleration. jamers 1999 - 2003 7.3L Power Stroke Diesel 8 12-07-2016 06:43 PM
Truck won't start! Help Michael Cieslik 1999 - 2003 7.3L Power Stroke Diesel 18 12-03-2016 09:07 PM
94.5 runs rough, hard or no start when hot. Just bought AE. naga77777 1994.5 - 1997 7.3L Power Stroke Diesel 30 01-27-2016 06:32 PM
Here we go again with a crank but no start FiznUKa 1999 - 2003 7.3L Power Stroke Diesel 3 08-29-2015 07:20 AM
95 7.3 still no start Kowdog 1994.5 - 1997 7.3L Power Stroke Diesel 45 01-08-2014 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
