tree limb trimming question?
Old 06-16-2013, 04:29 PM
cjben's Avatar
cjben
cjben is offline
I have about 20 trees in my front yard. some of the limbs are hanging low enough that I can't get the riding mower under them to cut the grass. Would it hurt the life of the trees if I were to cut the low branches as long as I didn't cut the main trunk of the trees? sorry for the silly question but I know next to nothing about trees except they grow leaves in the spring and lose them in the fall.
Old 06-16-2013, 05:13 PM
04badford's Avatar
04badford
04badford is offline
If they are mulbury yes you cant hurt these trees, if burch dont trim but a few you will put that tree in shock,If any kind of fruit or citrus cut the branches that are pointing directly down ward,nothing going to the sun .do you know what kind of tree they are?
Old 06-16-2013, 05:15 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
They should be fine if it's just a couple. Just start out by cutting about a third of the way through on the underside about 12" away from the trunk, and then cut from the top just beyond that. That way, when the limb starts breaking towards the end of the cut, the piece it peels off won't go down to the trunk. After the limb is dropped, cut the stub back close to flush with the trunk.
Old 06-16-2013, 06:53 PM
johnday's Avatar
johnday
johnday is offline
Ya, what kind of trees? If they're any type of pine, you can trim them, but they won't look right.Do you have any arborists around, or a forester?
Old 06-20-2013, 07:25 PM
shorebird's Avatar
shorebird
shorebird is offline
Contact your county extension office for information sources in your area.
Old 06-23-2013, 10:39 AM
19fifty4's Avatar
19fifty4
19fifty4 is offline
I limb mine up all the time. Haven't killed any yet. I usually wait until winter when the trees are dormant. Pruning properly done is good for the tree. Good luck.
Old 06-23-2013, 11:12 AM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
Received 4,678 Likes on 2,606 Posts
Most trees do well with a spring trimming. It promotes growth in other areas of the tree and promotes a healthier tree.
Furyus1
11-23-2010 01:56 AM
70blue
12-17-2006 10:35 AM
ranger rules
05-10-2006 09:24 AM
thunderguns71
10-07-2004 06:54 PM
Greg 79 f150
02-08-2004 06:22 PM
Quick Reply: tree limb trimming question?
