intrmittent electrical
Old 06-16-2013, 01:58 PM
Jake321's Avatar
Jake321
Jake321 is offline
Hello
I have a 2002 F350 superduty XLT 4x4 with a 7.3L power stroke.
When I go to start the truck, the dash warning lights flash on and off and I hear what sounds like a relay vibrating/buzzing noise under the dash. The glow plug light does not extinguish and the truck won't start. Turns over good but no start.
If I put my foot on the brake everything works 100% normal. As soon as I release the pressure off the brake it stalls. If I,m quick to put the pressure back on the pedal it keeps running. If I ride the brakes I can drive the truck.
This problem is intrmittent and never duplicates when I've had it at the Ford Dealer.
There are no fault codes showing. New battery's and new Alternator. They also replaced the DPFE 3 sensor assembly.
Old 06-16-2013, 03:38 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Sounds like you have a short or something with the brake circuit. The EBP Sensor probably had nothing to do with it though.
I would start checking around the brake pedal assy and see if there is a chaffed wire or something. Next thing I would do is disable the brake switch and see if your problem goes away or not.
Old 06-16-2013, 04:00 PM
Jake321's Avatar
Jake321
Jake321 is offline
Thanks Ken I'll start with that. Won't be till next weekend, I let you know what I find.
48' fordster
02-06-2010 03:17 AM
55krazy
1999 to 2016 Super Duty
06-28-2009 08:20 PM
jmtbiggin
06-14-2007 01:39 AM
67f100
1983 - 2012 Ranger & B-Series
03-05-2006 08:34 PM
Quick Reply: intrmittent electrical
