intermittent electrical - Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Puddy
Old 06-16-2013, 02:18 PM
Jake321 Jake321 is offline
Jake321 is starting off with a positive reputation.
Hello
I have a 2002 F350 superduty XLT 4x4 with a 7.3L power stroke.
When I go to start the truck, the dash warning lights flash on and off and I here what sounds like a relay vibrating/buzzing noise under the dash. The glow plug light does not extinguish and the truck won't start. Turns over good but no start.
If I put my foot on the brake everything works 100% normal. As soon as I release the pressure off the brake it stalls. If I,m quick to put the pressure back on the pedal it keeps running. If I ride the brakes I can drive the truck.
This problem is intrmittent and never dupicates when I've had it at the Ford Dealer.
There are no fault codes showing. New battery's and new Alternator. They also replaced the DPFE 3 sensor assembly.
Brake light on? Bottom left corner of dash 69 f250 zak8tac 1967 - 1972 F-100 & Larger F-Series Trucks 23 12-06-2014 01:56 PM
Brake Issues BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 27 11-08-2013 10:44 AM
intrmittent electrical Jake321 1999 - 2003 7.3L Power Stroke Diesel 2 06-16-2013 05:00 PM
1978 f100 4x4 brake warning light question jehawk55 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-18-2011 11:22 PM
Master Cylinder, Brake Pressure Switch Problems MC04 1997 - 2003 F150 3 07-11-2005 08:59 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
