239 flattie head removal
over heating
but getting back to the heat thing.. with new rad, hoses, stat's, and flushing out the engine, it just looks like a blown gasket.. it takes only about 3 miles to get it heated up.. way too fast..
water pumps ???
let me state again that i'm very new to flathead motors... other then looking into the rad, is there something else to look at.. no i don't want to pull the heads. one thing keeps comming to my mine.. prev owner mentioned the guy he got it from did some motor work.. well when i pulled the carb to rebuild the gasket between the 2 parts of carb was very old.. pulling the stat's the gaskets looked old too.. both in that brownish color old looking...
It doesnt sound like a head gasket. dumping that much water in 40 miles the oil would show or you'ld have a cloud of smoke/steam following you.
You got to find out why its running hot or blowing the antifreeze out the overflow. Do you know if the motor has been bored oversize? If its bored out a lot then you may have to put a better cooling system under the hood. Especially if you driving stop and go in town. Maybe a hotter thermostat?
Pull the thermostats, fill the radiator so you can just see the antifreeze. Run the motor with the radiator cap off looking into the radiator for bubble (big bubble like your compression is entering the coolant) or if the anti freeze is rising up to the filler neck and overflowing faster than it can filter through the radiator.
Also, since you had fuel problems, make sure your not running lean or your ignition timing is off.
Sorry about this but make sure that your thermostats have the coils pointed down toward the hot engine. Sorry for such a simple thing but that mistake has been made before.
pete don't feel sorry for simple suggestions...
i'm sure everyone has done something dumb at one time.. but the stat's are pointing down.. but talking to my brother a few minutes ago he mentioned since i had fur ***** in ea stat and the rad might have been plugged he mentioned the water passages just might be plugged too.. hadn't given that a thought. so i'm just going to order the parts and pull the heads.. better safe then sorry.. it looks like a piece of cake.... ya right.. i'll just make it down to a learning experience. my distance the second half was around 5 miles, i put a gallon of water in to fill it up saturday and I ck'd it a while ago and can't see any water in rad.. i'm gonna call a friend and see if i can get the cooling sys pressure tester..
Well it is not only the initial timing but total advance. Before taking all those bolts off the heads I would do those simple checks first. Here are a few old articles that might help you.
#28
I have similar problem with flathead 226, does not run hot 160-180 losing water through exhaust,did dye test in radiator combustion in radiator, installed new copper head gasket,magnafluxed head ok ,milled surface ,still losing water not antifreeze through tailpipe,no antifreeze in oil ,signs of water hot or cold,4th gear no power,detonating sound,dont know what else to do
#29
#30
blk dog
12-19-2010 03:40 PM
Alcaeus
10-05-2009 01:47 PM
