6.2 Have Enough power to pull 14 big round bales - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 06-15-2013, 09:04 PM
mattiessuperduty mattiessuperduty is offline
mattiessuperduty is starting off with a positive reputation.
I was wondering if a 6.2L F-350 would have enough power to pull 14 big round bales. I have a 2007 F-250 with a V-10 right now. I like the power of it but hate the gas miles.
Old 06-15-2013, 09:47 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
How much do 14 round bales of hay weigh? I liked the torque my '08 V10 has compared to my '13 6.2.However the 6.2 has a better top end than the V10.
Old 06-16-2013, 06:36 AM
1500 to 1600 pounds apiece.
Old 06-16-2013, 11:43 AM
BigMix's Avatar
BigMix BigMix is offline
BigMix is starting off with a positive reputation.
The short answer is yes.
Now for the reasons why you probably shouldn't.
1. Legality- Even with the 4.30 diff only goes to 16.5K tow rating.(I know it's a real buzz kill, but someone was going to say it.) 14 bales at 1600lbs is over 22,000lbs not including the trailer.
2. If your trailer does not have brakes or the brakes go out, it will take a long time to stop.
3. Pulling that much too often will put undo strain on the engine/drivetrain. Engine life will be shortened.
Old 06-17-2013, 06:15 AM
What if u put air bags under the back wheels? That would help take some of the load off.
Old 06-17-2013, 07:43 AM
jorlee jorlee is offline
jorlee is gaining momentum as a positive member of FTE.
Ya, it could do it, but why for only 14 get a semi and trailer and haul 24-30 depending on trailer size. Could get a semi and trailer cheaper, than a pickup and get the same mpg's.
Old 06-17-2013, 04:39 PM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
I had my 6.2 and trailer hauling rock when I added on to house - You weigh in - weigh out every time you leave the quarry. Total truck trailer/load max was 29,500 - The truck pulled it just fine.
I was sweating bullets - worried about trailer tires and axles.... I was on farm to market roads for 30 miles and not worries about police or traffic..
As for the question - it can be done - but if you are doing it on a regular basis you really should get a bigger rig - if you are just hauling them out of the field to headquarters each cutting - no problem -
Old 06-17-2013, 09:23 PM
I don't do it everyday. When i do haul hay ill haul about 7 loads a day until i get it all hauled.
'73/'76/'79 F250 4x4 Pinhead-227 1973 - 1979 F-100 & Larger F-Series Trucks 23 05-05-2015 08:50 AM
2014 F-250 Upfitter Switches derson38 1999 to 2016 Super Duty 2 03-05-2015 09:16 PM
F250 hauling 18k-20k? meborder 1999 to 2016 Super Duty 85 10-13-2012 12:42 AM
Tailgate strength CornTruckDriver 6.7L Power Stroke Diesel 18 08-31-2011 07:49 PM
Tailgate Strength flyinnuts 6.7L Power Stroke Diesel 19 05-22-2011 07:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
