2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Help removing Navigator door panel 2003
Old 06-15-2013, 06:15 PM
Adriandude8544's Avatar
Adriandude8544
Adriandude8544 is offline
I need to replace the door latch on my 2003 Navi. To my understanding I have to remove the entire door panel,can I get some help with that? This is for the rear passenger side door. Thanks in advance! Pictures appreciated. I am trying to save money, so please don't tell me "go to a dealer or a shop."
Old 06-16-2013, 01:42 PM
pozner's Avatar
pozner
pozner is offline
I've removed plenty of door panels, just not a Navigator. Generally, they are all similar. I'll try to get you started. Others will provide specific info.
First, look all around the door for any fasteners that will need to be removed. Some are hidden under small panels, door switches or courtesy ligt covers. Also look under the arm rest for holes that hide fasteners, if they still do that.
Will need a wide flat blade screwdriver for prying off covers.
You will need a phillips head screwdriver.
You may need a small nut driver, probably 5/16, but maybe not.
*Steel chisel & 4 lb sledge hammer. *(just kidding)
Once the fasteners are out and electrical switch panels disconnected, the panel will lift UP off the sill, then pull away from the door.
Putting it back on can be slightly more fiddley. Have patience and take your time.
These are basics that apply to almost all modern vehicles. Take a peek at the door panel video to get a better idea.
Remove front door panel.
Replace exterior door handle
Old 06-22-2013, 01:58 AM
pozner's Avatar
pozner
pozner is offline
You're welcome.
Old 05-28-2014, 10:34 AM
Adriandude8544
Hi sorry for the BEYOND late response, your reply was super helpful! Thank you very much!
Joelski
1983 - 2012 Ranger & B-Series
08-11-2006 08:17 PM
sacky07
02-08-2005 07:33 PM
faroffthetrack
07-03-2004 06:07 PM
alabamabuddog
06-06-2003 10:36 PM
RVBfordman
1997-2006 Expedition & Navigator
05-15-2003 04:59 PM
Quick Reply: Help removing Navigator door panel 2003
