what is drone? - Ford Truck Enthusiasts Forums
what is drone?
Old 06-15-2013, 11:58 AM
riverguideguy riverguideguy is offline
riverguideguy is starting off with a positive reputation.
what is drone?
im lookin for new mufflers for my hiboy and i been checkin out all kinds of auto and truck forums online and the one word that keeps poppin up over and over again is DRONE DRONE DRONE but no one ever explains what it is. what the hell is drone
Old 06-15-2013, 12:13 PM
460 FORD MAN's Avatar
460 FORD MAN 460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
Drone is kinda like if you hum at a content level. Some say it's annoying, but it doesn't bother me.
Old 06-15-2013, 12:33 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Put some loose change in your ashtray, when cruising down the road at a steady rpm the coins start to "dance" that's exhaust drone (it kinda makes a "Hmmmmm" noise that 460FM mentioned above).
It's caused by the turbulence through the mufflers resonating through the frame and floor boards (i'm sure there's a more scientific explanation, but we'll just go with this one for now ).
Things you can do to alleviate it are...have a properly routed exhaust, install a crossover pipe (X or H), use rubber mounted hangers, use sound deadener and good floor matting..... or just turn up the radio.
Old 06-15-2013, 01:04 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Glass packs are usually the ones guilty of drone. Not always but a good majority of trucks that drone have some sort of glass packs. As said above, crossovers (x pipes help).
My fathers ranchero gt had magnaflows with no crossover and it droned like a ******* at idle. It rattled that little truck like nobody's business. I liken it to haveing a little single engine prop plane in the cab.
Old 06-15-2013, 02:37 PM
liquor crazy liquor crazy is offline
liquor crazy is starting off with a positive reputation.
I used to have a 2500 ram with the cummins I had a bunch of work done to it . before I sold it I had tried a big single turbo instead of twins and w no muffler just the turbo and 5 in pipe all the way out the back, that thing when it reached 2000 rpm on highway felt like your ears were going to pop. it was weird .
I had rode in other trucks and they didn't have that same loud deep constant annoying sound. like a gang of 200 people humming as loud as they can .
in retrospect a muffler would have been a good option. but I enjoyed it then being obnoxious and blowing smoke on people, racing beating mustangs and Hondas, but have matured a little since then.
Old 06-15-2013, 05:45 PM
ahh i get it now i hear that sound mostly on ricers i just never knew it was called drone. i was leaning towards flowmasters cuz everyone says they are best but everything i read on em that drone word comes up. i was lookin at glass packs to anyone ever use cherry bombs or purple hornies? seems like every new truck around here has that flowmaster sound which is kinda boring. i want something more tough sounding but not crazy loud like strait pipes.
Old 06-15-2013, 07:08 PM
stp1971's Avatar
stp1971 stp1971 is offline
stp1971 is starting off with a positive reputation.
Ever have a woman go on and on and on and on about nothing you care about? That's drone. J/K
I've always associated it with a metallic humming noise that comes on at certain RPM's or speeds. Ever seen a metal tuning fork? Hit them together and they make that vibrating humming sound. The vibrations in the metal forks are caused by specific frequency. Same thing the specific frequency of the exhaust note at certain pitches will cause the metal to make that sound.
My motorcycle does the same thing at certain speeds.
Old 06-15-2013, 07:26 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
To sum it up, it's called "resonance" or the first harmonic.
Old 06-16-2013, 10:55 AM
Quote:
If they're louvered core i'd shy away, if they're perforated core go for it.
Old 06-16-2013, 01:15 PM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
the sound of a short fat glasspack can not be beat, IMO. the thrush welded do sound pretty good too. i've got those on my chebbie plow truck, there is some drone at idle, but that's it.
the dent wears a single short fat glasspack, again, some drone at idle, but nothing at speed.
as HIHO said, look for a perforated core vs a louvered core. Every thrush i've looked at is perforated FWIW. they may make a louvered core, but i've never run across one.
shorter = louder
longer = quieter.
Old 06-16-2013, 07:02 PM
Quote:
Quote:
how do I tell the difference between the two??
happy dads day to all you dads out there
Old 06-16-2013, 09:11 PM
jgavac's Avatar
jgavac jgavac is offline
jgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to alljgavac is a name known to all
If you look down the inside of a glasspack, and you see little fins sticking up towards the inside of the pipe, it's louvered. If there are just a bunch of holes like perforated pipe, its a perforated core
Louvered
Perforated
It's true that packs are often the culprit of droning. Mine was terrible when the muffler was right under the passenger floor and dumped right there. After I moved the muffler rearward about a foot and put a 45 degree turndown, no issues.
-Jameson
Old 06-17-2013, 01:10 AM
^ ditto
Those pics look familiar
Go perforated core only.
Old 06-17-2013, 01:11 AM
jgavac's Avatar
^ ditto
Found em' on Google
x2 with perforated. Louvered tends to blow out fiberglass, and they are directional
-Jameson
Old 06-17-2013, 01:20 AM
Quote:
Originally Posted by jgavac View Post
Found em' on Google
As did I
Someone asked this very question a few months ago......nobody uses "search" anymore.
2V V10: Y-pipe goes on tomorrow, which muffler? truckfella Modular V10 (6.8l) 26 08-18-2015 09:29 PM
97 7.3 exhaust drone? jd_green Exhaust Systems 1 02-28-2014 10:55 PM
Low Tone Drone in the Cab at Idle SneakyF350 6.7L Power Stroke Diesel 9 12-21-2011 08:21 AM
Input on homemade exhaust wmiller 1994.5 - 1997 7.3L Power Stroke Diesel 17 03-15-2011 09:37 AM
What is turbo drone? Heckler 6.0L Power Stroke Diesel 13 11-11-2004 02:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
