trying to figure out my gearing - Ford Truck Enthusiasts Forums
Old 06-14-2013, 10:47 PM
Bluethunder3320 Bluethunder3320 is offline
Bluethunder3320 is starting off with a positive reputation.
i am upgrading the axles in my 78 f-150. converted the front Dana 44 to a 3/4 ton using chevy k20 knuckles/spindles/hubs. i just got a Dana 60 for the rear and i don't know if i need to change the ring and pinion.
so my question is, what were the options for gearing on my truck? it is a 78 F150 Ranger 4x4 styleside, 400 c-6, 9 inch rear. the door jamb stickers have been painted over
my vin number is F14SEBG1005
there is a small tab with numbers on it that is bolted onto the front axle. are these helpful?
if all else fails i'll have to take the cover off the front axle and see if i can count the teeth
Old 06-14-2013, 10:51 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Yes.. it'll likely have a Bill of Material (BOM) number which you can decode using Dana-Spicer's reference manual. The link is in the tech thread hyperlink sticky.
The BOM is also stamped on one of the axle tubes...
Old 06-15-2013, 03:13 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Dana 60 may have a plate with 7 or 8 digit Dana ID number (examples: 603010-1 or 603010-11) bolted (2 bolts) to housing adjacent to inspection cover.
The Dana ID number may be stamped on the axle tube. If number has 7 or 8 digits, post what it is.
Ford ID tag located under one of the bolts that retains inspection cover to housing. Many of these tags missing today.
Old 07-18-2013, 09:52 AM
I had taken the tag off last time I changed the gear oil because it twisted when I tightened the bolts. I kept it, in a safe place that I don't remember.
Ill look for some numbers on the tube. If I still can't find anything ill just take the cover off again.
Old 07-18-2013, 10:08 AM
AXLE code stamped on the 2nd line-far right of the metal Warranty Plate, located on the left door face below the latch.
Glued to B pillar Safety Standards Certification Label that's been painted over does not have the axle code printed on it.
VIN does not contain trans or axle codes.
1995 Ford F150, 5.0L, 4WD, Dana 44 TTB Front Axle Tag Interpretation OFLM 1987 - 1996 F150 & Larger F-Series Trucks 9 12-13-2016 01:58 PM
Dana 60 and Dana 70 Axle ID Help 78 Ford F150 460 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-15-2016 03:52 PM
Solid axle swap BLK SHP Clutch, Transmission, Differential, Axle & Transfer Case 5 01-17-2011 06:49 PM
dana? bill of material number 610049-5 timothy47129 Clutch, Transmission, Differential, Axle & Transfer Case 4 12-09-2006 02:30 PM
dana 30 gears fordmaniac21 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-05-2002 08:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
