I have changed Fuel Filters, Unplugged battery and plugged back in and the "Water in Fuel" saying keeps coming on. Is there a way to reset? Need some help. Thank you.
Ford changes the fuel pump module if cleaning doesn't work. Sensor is behind Allen plug on module, and once it gets corroded enough can't be cleaned enough to turn light off. Hope this helps
